Pionerr elite big screen comes on for a while and then "pops" screen shows some colors of the spectruma dn tehn goes blank...turn it off for a while and its ok...can run for days without failing...heat related?
    Novelist:
    Champion:
  • 203 Answers
What is the model number? There are a few models that had this as a very common problem where the power board had bad connections, very easy fix, all you have to do is solder the **** out of the board. If you give me the model number i will be able to tell you if yours is one of these, and if not what we can do next. Let me know
Tim Nolan
Posted on Sep 24, 2008
My Phone Screen Wont Turn On, Even When I Put It On The Charger
Hi take off your memory card and format it 3times, by the way you should do same format for your cellphone. It is a software problem.cheers
Nov 25, 2013 | ZTE Score
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
When i switch on my laptop, the screen come to a grey color and then to black but don't show me the icons on desktop. it looks like switch off...
Perform power drain (remove all the accesories inclusing battery and the charger) press the power button for 1 minute.
Connect the power adapter tehn turn on the computer.
If issue still persist posible issue with the hardware MoBo
Mar 27, 2010 | Dell XPS M1530 Notebook
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung TV made a big ''POP''
replace the color wheel
Sep 13, 2009 | Televison & Video
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
