Question about Gupta Team Developer for PC
SQL Invalid cursor number 135 error
We are having this error as given below when we are running are schedule job.
The message which appears on the log file is given below. I dont know what SQL 135 Invalid cursor means.
Could you please give us some information regarding this issue.
SQL ERROR INFORMATION
CODE [DB0101]
TEXT [SQL 135 - Invalid cursor number.]
DESCRIPTION
Centura Error: 135
Centura Message: Invalid cursor number
Centura Function: sqlcom (compile statement)
Native Error: 0
Native Message:
STATEMENT
SELECT TRANSACTION_TYPE FROM TRANS_HISTORY WHERE LINK_NUMBER = :1 AND ACCT_ID
= :2 AND CLASS = :3 AND UNIT_NUMBER = :4 AND CERTIFICATE_NUMBER = :5 AND TRANSACTION_AMOUNT
> 0 ORDER BY EFFECTIVE_DATE
ERROR MESSAGE
SQL error 135 in User Function 201296/SQL 4 (selTransactionType)
- function/info v We are having this error as given below when we are running our schedule job.
CODE [DB0101]
DESCRIPTION
Centura Error: 135
Native Error: 0
Native Message:
STATEMENT
ERROR MESSAGE
- function/info values = DB_Compile/none
Regards,
Jawad
GESB
Australia..
  • Raph30 May 11, 2010
    Can you please specify what platform and application the sql error is being generated?
    Also, are the same number of fields being passed to this statement from the cursor?
    Thank You,
    Raphael
    Social Spider:
    An expert who has shared 50 answers on their Facebook wall.
  • 43 Answers
I think the problem is caused by the line of code:DB.Close
(7 lines from the end of your function).
Try commenting out the call to DB.Close
Posted on Jun 09, 2016
  • 258 Answers
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Posted on Feb 10, 2009
What causes an error 49,2F9D on a HP LaserJet P3005N Printer
Hello thanks for using FixYa
This is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
    I hope this solution will helpful 4 u
    Please don't forget to click on Four thumbs which are given below if it is helpful
    THANKS & Keep Using fixya
Feb 16, 2011 | HP LaserJet P3005 Printer
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
ERROR 49 DE LASERJET 1522 MNF
  • device.
Jan 25, 2011 | HP LaserJet M1522nf Multifunction Printer...
Error 49.4c02 comes up whenever i want to do duplex printing
  • device.
    Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
Jan 21, 2011 | HP LaserJet 4250dtn Printer
Error core: 49. 4 C02 service error?
  • device.
Jan 19, 2011 | HP LaserJet 4250dtn Printer
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
Whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Database talks to code but code won't talk to database
Make sure you are connecting to the database,then just before you call your sql to insert use an echo statement to display the sql and check it for syntax:-
$sql = 'insert into table1 values('.$no.','.$no.',"block","'.$value3.'", "'.$value4.'")';
echo "SQL ==>" STARTOFSQL<br>".$sql." ENDOFSQL<br>";
Jan 18, 2009 | The PHP Group PHP
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Computers & Internet Logo
2,666 people viewed this question
Top Gupta Computers & Internet Experts
David Payne
David Payne
Are you a Gupta Computer and Internet Expert? Answer questions, earn points and help others
