Question about Garden
Echo cs8000 Hi. I have aproblem with my saw. The bore and piston were badly scored so I replaced them. The saw goes to fire after about three pulls with the choke. I push the choke in and then it will start. It will idle and rev, but only for about 10 seconds. It seems to run out of fuel. You can repeat the same stsrting sequence over and over and the same thing happens. I have checked the fuel hose and strainer in the tank. I have dismantled and checked the carby and no obvious problems, The hose from the crankcase is connected but I dont know how to test any further. Any help or suggested would be appreciated as I love the Saw but I might look at a divorce the way things are going. Regards Matthew
    Problem Solver:
  • 7 Answers
The solution to the fuel starvation problem with the Echo 8000 is based on the metering diaphragm. In late 2007, Walbro sold off a huge amount of carb kits which were not ethanol compliant. These kits were purchased by resellers like Stens. Now that many states have ethanol blended gasoline, the metering diaphragm dissolves and hardens in the presence of the added ethanol. You will need the walbro carb kit with a 'new' metering diaphragm that is not sensitive to alcohol or mtbe which is the summer fuel additive also in alot of areas. Each kit comes with a date on the package, use Walbro K22-HDA manufactured after 06-2008. I run these saws that is how I know.
Posted on Aug 31, 2009
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 29, 2008
I have a husqvarna partner K960 concrete saw that the skirt of the piston on the exhaust side has shattered, there is no scoring in the bore, the actually sides of the piston above the damage has no...
If the piston is working in the cylinder properly, that part of the piston shouldn't be making contact with the cylinder wall so lubrication shouldn't contribute to its demise unless it was bad enough to lead to enough heat buildup to cause the failure. It is most likely the metal was weak in a way or spot that the force of the piston going up and down was enough for the metal to finally fail. Of course the faster the motor is turning the higher those forces are so over reving the motor could certainly lead to this type of failure.
Sep 10, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
371 ran great quit , restarted quit again ,checked comp , 60 lbs
hi there ricksq
take the muffler off - have a look at piston / rings and bore , i suspect you did not put enough oil in the petrol or forget to put oil in petrol and ran on straight fuel or on a very very lean oil mix
if you see quite deep scores and gaulls on piston / rings / bore - might pay to invest in a new saw or a new piston and cylinder kit for these machines
have a look
let me know what you find
cheers pauly46
Jun 02, 2011 | Garden
Hi, I'm having problems starting my new morrison bc230b weedeater... I think whats happened is the wrong fuel was put in it..(no oil mixed) .is there a quick fix? thanks
hi there
walkersworld
if you have run the unit with no oil in the mix ie straight petrol
you will have damaged the piston / rings / bore - do a compression check - if its quite low
check - remove the muffler and check for score marks on piston and rings and bore
if so , the unit may not be worth repair , because compression will be lost past damaged rings
and with damage on piston more scoring / damage will occur
so answer to is there a quick fix - no especaily if what find when you look up the ex port at piston / rings/bore
have a look
sorry for bad news
pauly46
May 31, 2011 | Garden
I've had my echo under a year. Haven't used it much, but on the last project, it seemed to lock up after a couple of hours. I shut it down, and upon trying to restart it, the starter cord would not...
hi there chris
pauly 46 here
if you have taken the starter cover off and the chain and bar are off and the flywheel will still not move
take the muffler off and the carby off too and have a look at the piston and bore if they are scored deeply on the intake and ex side and the bore has damage as well - it sounds like you mave have runn the unit with not enough oil in your mix or you used stale fuel
if you have run a mix with not enough oil in it or no oil at all ( this is operator error )
and is not considered a warrenty condition!
either way repair could be expensive- might pay to think about new saw because to me thats what is sounds like !
but before pulling it down any further - you may want to check and see if the unit had any air leaks
that may have caused it to run lean ( the only way to know is to pressure and vacuum test the crankcases / manifolds for leaks ) especially if you know you mix was good and not stale.
The reason i say this is because you stated the unit is under a year old ( it may be a warrenty)
condition and i state MAYBE a warrenty condition if the unit had a air leak and was run on the correct mix and fresh mix , and the settings for hi / lo were not altered
might pay to check this out
echo is a very good product
PS pressure and vacuum testing is best done at your local outdoor power repair shop
cheers let me know what you find
pauly46
Apr 29, 2011 | Echo CS400 18" Chain Saw
I have a 2000 yz 125. Melted a hole in the piston but didnt score cylinder. Replaced top end. Wont start. Has good fire. Crank case oil was a little grey. New plug,fluids,fuel.
I would be checking compression it may not be visible score on cylinder but it does not take much to loose compression on small bore motor with one piston ring and 11 years old
Mar 03, 2011 | 2003 Yamaha YZ 125
I ran my echo 14 inch with no air filter and now it wont start
Remove the muffler and check the condition of the piston/ring(s) and cylinder. If badly scored, you have probably drawn in enough debris to damage these items. The fix is to replace these parts--warranty, if any, won't cover this type of damage, and the cost of repair approaches the cost of a new saw. Hope this helps!
Dec 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Have a Husqvana petrol chainsaw that i ran at the weekend on unleaded petrol (forgot oil additive!) and now it wont start. Have drained out the fuel and now put right mix in (50:1). still wont fire. any...
Your saws piston is probably shot. To check remove the exhaust, to do this remove the retaining bolts and take the exhaust off. remember the order you take off the parts! When the exhaust is removed slowly pull the saw over (with the on off switch off) look at the piston as you do this. If there is any visible scoring the saw is unfortunatly knackered. You can replace the pot and piston but it's usually expensive!!
Sep 21, 2009 | Husqvarna 16 In. Chainsaw Replacement...
I have a Craftsman Blower/Vac model 358.794770 that won't start. I'm not getting any spark from the plug when I pull the rope. I've replaced the plug, ignition module and the wiring harness but it still...
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Sep 12, 2009 | Craftsman Garden
Echo CS8000 keeps burning up spark plugs
I'm not a small engine mechanic but it kinda sounds like its running to lean, not sure if there the same but if 4 cycle engines run way to lean they detonate and can melt a piston. Most of the time they will run fine under no load but once under load it will cause the detonation. If you have a compreesion gauge see if it has any compression if you dont have a gauge just put a finger over the spark plug hole and pull the starter to see if it builds any compression, if no compression probably a hole in the piston or bore hope this helps
Jan 20, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
236 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
