I have a sears kenmore elite washer mod# 110 20952991, and the agitator works,but doesn't move around, sounds like it is stripped ! Help !!
  • 172 Answers
If the entire agitator is not moving you will have to replace it. If the top is not working properly, you will need the 4 little gears inside the top calle d agitator dogs. The set of four cost about $8.00 and are available at any appliance parts store. To get to the agitator dogs you will remove your fabric softner dispenceer, if you have one. Then pop off the top lid of the agitator. It will have a small spot to insert a screwdriver and pop it off. Then reach down inside the agitator and pull out the next little cover. Be carefull not to loose the seal. Then you will need to unscrew the bolt that you see in the bottom. Once you have done that the agitator will lift off. The top will not pop off the bottom and you will be able to see the four little tear shaped gears called DOGS. I love the name. You should be able to install the new ones fairly easily and then just line the top of tha agitator up with the bottom and push it back down into place. If you look down inside the agitator you will see two little clips that you will need to line up. It is really an easy repair. Let me know if you have any other questions.I hope this will FixYa. Please rate me when you can. Mike
Posted on Sep 24, 2008
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
I have a Kenmore Elite washer and the agitator is making a stripping(slipping) noise and it is not rotating all the time. Thanks
This assumes that you have a basic Kenmore2_bing.gif / Whirlpool2_bing.gif top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
I'd also check the Motor Coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Jan 17, 2010 | Kenmore Washing Machines
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 06, 2009 | Kenmore 15864/15862 Top Load Washer
Agitator not spinning
agitartor stripped
you can order the dogs at sears
agitator dogs
Oct 04, 2009 | Washing Machines
Agitator on my washer is loose
Replace the agitator dogs in the top part of the agitator. Parts are about $7.00.
Jul 17, 2009 | Kenmore Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
