Panasonic 5 disc cd mini stereo model:SA-AK17,year:Aug 1999,when turned on the relay clicks then the display reads "F61" then the unit turns off.I unsoldered and removed audio output IC module pcb location:
and now the unit turns on normally but when shut the unit off it turns on again shortly after,I assume it is because the IC is missing am I correct?and just to be 100% sure it is the IC that is defective correct?.Thanks in advance for replys.
-   ALGUEM SABE QUAL O CODIGO IC DO SOM MINI SYSTE PANASONIC SC- AK22 -   Guest
Oct 31, 2008
-   my panasonic mini switches off automatically during my listening and an error messege F61 get displayed for seconds -   esigudla
Oct 20, 2008
-   hi my problem is with an AIWA nsx-s777 when I switch to cd player it keeps clicking for 6-8 times, but it will not open so as I can load a cd,radio and tapes work fine, also I am looking to buy a panasonic scak17 but it has no remote, has anyone got the details or code no, so as I can buy one
many thanks
chris-   lisadecades1
Oct 20, 2008
-   hi can anyone advise, just bought an AKAI nsx-s777 when I switch on to cd-it keeps clicking for about 6-8 times but it will not open to let me load a cd radio and tapes are fine, I am not very good with electrical equip,
thanks-   lisadecades1
It's not the IC that is wrong, the problem is that the output line going to the speaker is probobly shorted. check if the balance is working properly between the left and the right. if this is ok then the fault is in your speakers. check it for shorted wi
F61 for sure is the meaning of audio fault , it could be either from the audio IC , or from the CPU , or from the power supply .. first if i was you i will check the DC O/P of the final amp to determine if it's from the IC or not take care of the fusible resistors near the IC if the IC is faulty they went too... (just for an advise Don't waste time on it if it's not your set... cause the IC is bloody expensive about 50/60 euro and therefore is not worth repair)
Was this helpful?
Yes
No
Popular Solutions for Panasonic SC-AK17 Shelf System
Bought the unit used. when you turn it on it is in CD mode, the drawer comes open and says remove...
(More)
Bought the unit used. when you turn it on it is in CD mode, the drawer comes open and says remove disc even if there is no disc in tray. It is stuck in cd mode. It acts like it is changing discs but doesn't. Help. By the way it is a 5 disc SA-ak17. Thanks.
following a power outage the system came on automatically and will now not turn off. Otherwise works...
(More)
following a power outage the system came on automatically and will now not turn off. Otherwise works well but it has to be disconnected from power to get it to stop playing We do not have a manual written in English language so cannot correct this problem. spanish manual is written for SC-AK27 and SC-AK 17
A few months ago I could not get any sound on cds, recently I could no longer get sound on the...
(More)
A few months ago I could not get any sound on cds, recently I could no longer get sound on the tuner. Everything else, lights, etc., seem normal..
