Question about JVC GR-D250 Mini DV Digital Camcorder
Rewinding on jvc grd850
  1. I recently bought a jvc camcorder to take back home on from a trip overseas , only to find that after taping , i am unable to rewind what i have taped even though i am touching rewind
    Problem Solver:
  • 5 Answers
You might still be in the record mode. Try switching to playback mode.
Posted on Sep 24, 2008
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
I have a JVC camcorder (GR-D750U) that takes mini-DV tapes. Recently it started skipping on playback or cutting out. It is also making a mechanical noise. If fast forward in play mode it is amplified. ...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 22, 2011 | JVC Video Cameras
Doesn't sound like tape is recording or rewinding, power is up and unable to do anything because of e04 error
An e04 error is an error given by JVC camcorders that relate to a video head failure in the camcorder. The video head needs to be replaced as well as alignments to the unit. I hope this helps.
Sep 06, 2010 | Cameras
My camcorder will not play, it will rewind and fastforward but it wont plan, can you help me? it will also record but it won't play what has been recorded
sound like the play back head may be dirty,,,
try a cleaning tape first if that dont sort it out its a trip to the repair shop with it
Oct 26, 2009 | JVC 580136 Camcorder
JVC GR-D850 Mini DV Camcorder
i had the same problem it turned out just to be condensation.
Apr 04, 2009 | JVC GR-D850 Mini DV Camcorder
JVC GR-D33U won't play back some tapes
The tape cleaning won't help this problem, it is alignment on tape guide and back tension, like you mentioned it had been service before after they fixed the lens cap issue, usually they connected to computer to adjusted may be they missed. So I sugges you to bring it back to them if it is still under warranty or direct to JVC and take the old tape, ask them to try it after they align this unit, DO NOT use tape cleaning again because you can see picture on the new recorded
that mean the video head is good
I hope that give you some ideas
Dec 08, 2008 | Canon ZR100 Mini DV Digital Camcorder
EO3 FLASHING
I cleaned the heads with isoprophl alcohol on a q- tip and it started working again with no problems.
Apr 01, 2008 | JVC 580136 Camcorder
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Oct 28, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
Sep 24, 2007 | Sony Handycam CCD-TR416 Camcorder
Black or blank screen
your older recordings will only play on a pal monitor / tv ; if the camera video is ok now ? your tape heads may be dirty , wearing out - or both ; try a cleaning tape first but - do not rewind cleaning cassettes , or the old grime will be put back on the cleaned heads and guides ;
Jul 23, 2007 | JVC GR-D73A Digital Camcorder (PAL System)
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
112 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
