Question about Danby Dishwashers
Water pouring out of bottom during drain cycle. Hoses are secure
  • catheco Sep 24, 2008
    This is a Danby Portable DDW496W
  • Melissa Burke
    Melissa Burke Dec 22, 2012
    I am having the same problem with my Danby dishwasher, and i have found it is coming out of one of the holes on the bottom...is there a seal underneath that may need replacing?
    Sergeant:
  • 409 Answers
your problem is most likely the front panel itself. can you see if the water is coming from the front? this is quite a simple machine and there isn't many places the water would come from other then the hoses or the front panel under the door.
Posted on Sep 24, 2008
How to fix an E6 srror code for the washing machine
believe it to be a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Dec 12, 2016 | Washing Machines
Hobart sr24c is leaking water out the bottom of the door during operation.
You have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainage
Apr 21, 2016 | Hobart Dishwashers
LG WM2140C front load washer overflows during drain cycle
This sound like the water is leaking from the drain pump.
Dec 22, 2012 | Washing Machines
I have an error code E6 on my Bosch Front Loader Maxx Washing Machine, can you please advise what this error is and how to fix??
Hello there
Normally this is a drainage problem code
Mar 07, 2011 | Washing Machines
Water won't fill
it's syphoning caused by the drain hose in the stand pipe (wall) too far.
pull the drain hose out and stick in 6 inches only and secure to one of the fill hoses so it does not go back down too far. This will solve your problem
Apr 05, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
PTC22MFM - need to unclog defrost drain?
Normally, this is a job for an appliance service company. However, turn off the refrigerator and remove the rear freezer panel. Once removed you should see a drain hole. Apparently, water does not drain properly. Use an extended coat hanger, etc. to place down into the drain hole with "up and down motions". Periodically, pour a small amount of water into the drain hole until it appears to be unclogged. Then follow up with some hot water and liquid bleach (perhaps a cup full). This should kill any algae, etc. and remove any other foreign objects from the drain line. If you pour too much liquid into the drain hole you may get an overflow at the bottom of the refrigerator (there is a small drain pan underneath the appliance that catches the water during the defrost cycle. Yet, the water collected in the drain pan, during the defrost cycle, typically evaporates and you should never have to regularly empty the drain pan. Good luck!
Feb 20, 2010 | GE Refrigerators
During a wash cycle water purs out of the filter
check to make sure that one the drain is not clogged second it my be the water pump going out that pumps the water out to the drain
Nov 28, 2009 | Hoover AAA140 Front Load Washer
Washer Maytag
the drain hose tear or broken/ clamp detached / need to replace.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Dishwashers Logo
278 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
