Question about Sony Playstation 3 (PS3) Console
PS3 Blu-Ray Drive Track Assembly
I read in one of your post that you could explain step by step how to align the tracks in a Blu-Ray Drive for PS3. Could you please do that- I have a PS3 that I know isn't aligned right, and it sounds/looks like you know what you're doing. Thank you.
  • techfreak4 Sep 26, 2008
    I had already done that- but I should be more specific about my problem. I replaced the laser deck- successfully. It reads CD/DVD/BLURAY and the disc spins great. But when I closed it up, it would sometimes not accept the disk fully. I noticed that the small door that covers the opening where the disc is inserted doesn't close once a disk has been ejected. Does anyone have any ideas on how to fix it- btw I've tried different tops for the BD drive and theyve all had the same problem. Also- when I turn it on, the drive motors spin in, like it expects a disk to be there. I'm pretty sure that they are related- but still have no idea how to fix it.
  • 55 Answers
Open the console and remove the disc drive (1 ribbon cable and the power cable). Flip it on the part with the board and remove the 3 screws at the bottom and the 2 one at the top. Remove the cover Remove the 5 screws and open the drive like a book. As you have the drive laid down . carefully remove the guiding mechanism(1 screw) on the left side of the laser deck there is a plastic rail that rests on a small plastic wheel. Push back that rail as far as you can until it clears the gears located on the wheel (you should notice a slight lowering of the laser deck). Carefully put back the parts and before you put the cover hook it to the console and try. Hope this will solve your issue.
Posted on Sep 26, 2008
M lg bp145 quit playing blue rays but it will play dvds. Why?
Blue ray DVD's are read by a Blue violet LASER. I know that sounds pretty obvious but the colour blue is closer to the upper end of the spectrum and therefore has a shorter frequency and therefore you can generate and read much narrower data tracks. DVD's and CD use an older technology and use Red laser light which has a much wider and therefore less compact track size. So with a lower track density you get less information on a DVD.
The blue laser can be used to read both formats (and CD) but when reading the Blue ray disc the accuracy required is far greater to hit the track. Tracking errors caused by worn gears steppers and spindles can cause the Blue ray to miss the track but still have enough tolerance to read the much wider DVD/CD track.
The laser head isn't one laser, it actually produces two separate wavelengths, one for Blu ray discs and one for Red ray (DVD/CDs)
You can have a condition where the "blue-violet Laser diode fails but the red laser diode is still working. In this condition, it will exhibit exactly the effect you are experiencing.
Apr 14, 2015 | LG Televison & Video
Tip
Select subtitle and audio track when ripping Blu-ray?
Among the Blu-ray ripping tools, Pavtube Blu-ray Ripper is favored by most movie lovers for its high success rate of ripping and free switchover of languages and subtitles. It removes BD+ and AACS protections, and handles Blu-ray discs up to MKB version 10 and above so that the Blu-ray movies are attainable freely. Recently Dolby TrueHD codec had been added to the app, which enables users to access any of the audio tracks in Blu-ray discs. It is “able to open, copy, and watch every Blu-ray, irrespectively whether the Blu-Ray was bought in Europe, Japan or USA (i.e. all the three zones)”. (commented by Markus Nolff, a user of Blu-ray Ripper). This guide shows you how to select subtitles and tracks of different languages when ripping Blu-ray discs. A step-by-step guide is displayed below:
Step 1. Load Blu-ray disc.
Make sure you have had an external Blu-ray drive connected with your PC. Insert the desired Blu-ray disc and run Pavtube Blu-ray Ripper. (A free trail version of Blu-ray Ripper can be downloaded from here.) Now when you see the interface, click on “DVD ROM” and the app will import Blu-ray movie from the BD-ROM. Check the directory and click “OK”. Do not expand the folders and try to look for certain M2TS files, since the ripper will detect and put all the M2TS files in file list. You can load DVD in the same way, the ripper is able to cope with any DVD, either protected or not. If your source movie is in folders, click “DVD folder” to import the folders.
Step 2. Set subtitles and audio tracks.
One Blu-ray disc usually comes with multiple audio tracks and subtitles of different languages. Right under the file list you could find Subtitle and Audio option from where the subtitle and dubbings are set. The dropdown list shows you the detailed information, such as the subtitle language, audio language, codec, channels etc. Here you check the main movie (with longest duration), set the subtitle and audio track, and double-click the file to preview your settings.
Learn more: http://www.pavtube.com/guide/rip-blu-ray-movie-to-hard-drive-select-subtitle-audio-track.html
on Mar 18, 2010 | Audio Players & Recorders
Cannot get disk tray to open and disk will not play
I had issues like this on a sony once before here's what I did:
1) Take the top off so you can access the inside of the player
2) take out the Blu ray drive (usually held in by 4 screws)
3) open Blu ray Drive (4 more screws holding it together)
4) take q-tips a rubbing alcohol clan the Blu Ray laser eye
5) get some white lithum grease and lube up the track the Blu Ray drive moves on (2 metal rods the Blu Ray eye sits on) use a q-tip to apply.
6) get a can of compressed air and blow out the player before putting drive back together.
7) wipe off excess dust around player on Blu Ray drive, use the compressed air can on the drive as needed and once done....
8) reverse steps to put back together and it should work!
This is what I did for a 4 year old sony that was missing screws wasn't reading movies the drive didn't work, and now one year later the family I did this for is still enjoying their Blu ray player as if it were new.
Questions let me know!
Jan 06, 2014 | Vizio Vbr220
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 will not read my disc sometimes and other times it will read it but it will not work
    The disc may be quote, "Corrugated", hence the laser is having a hard time following mis ~ aligned structural pattern. Try to use a CD ~ Lens Cleaner. :)
    Apr 02, 2010 | Sony Playstation 3 (PS3) Console
    Player will not work. keep getting the disc will not work message, for all discs.
    HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
    You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
    Oct 06, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
    My ps3 won't play games
    Your blu-ray drive has failed.
    Check out my previous posts for a link to my blog site where I explain what you can do to fix this problem.
    I'm no longer allowed to mention the link directly.
    Aug 24, 2008 | Sony Playstation 3 (PS3) Console
    PS3 won't read game discs or DVDs
    no mate u need 2 send your ps3 back 2 sony this happened 2 me mate they havent got a solution 4 it they believe that the blu ray laser has burnt out meens you play 2 much lol
    Jun 14, 2008 | Sony Playstation 3 (PS3) Console
    Ps3 won't take in disc
    Sure have, the tray that takes the disc in is off track.I have had the issue with one of the ps3's that I had but I had to take it apart and reset the tracks.. Its a long process and could ruin your ps3. Call sony and see what they will do as its not a hard drive or an actual internal blu ray issue.. It might be 50$ to fix but its really worth it. If not I would be more then happy to walk you step by step to open and fix it... Or I would be more then happy to buy it and get you a great deal on a new ps3.. a 40gb 300$
    May 15, 2008 | Sony Playstation 3 (PS3) Console
    Toshiba SD-2050 problem reading discs
    If it reads only the first track, it sounds like a mechanical obstruction of the laser assembly (something is physically blocking it from travelling on its rails). If you are so inclined, try removing the deck lid andgently pushing the laser (in an area where there's nothing fragile) along its track to see if it frees up. It doesn't usually take much.
    Sep 20, 2007 | Televison & Video
    Sony Playstation 3 (PS3) Console Logo
    7,534 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
