Question about Honeywell Heating & Cooling
We have a Honeywell A/C (we believe it's a focus pro 6000) that is not working properly. The A/C unit itself is running but the vents inside the house are not cooling. We think it's a problem with the preprogrammed settings--the power went off earlier today.
  • 182 Answers
The honeywell is just a thermostat.my guess is the capacitor went out in the condenser when you lost power.turn the temp down on the thermostat and hit the hold button.....if it does not cool,call a service tech.good luck!
Posted on Sep 24, 2008
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Apr 30, 2017 | Honeywell Heating & Cooling
I have a honeywell thermostat, It keeps blowing even when I try to turn it off. Could you please tell me what is wrong with it? And can I fix it myself?
Do the easy stuff first! Is this a new install or has it been working well for a time and now it is not? Is the entire unit continuing to run or just the fan? Thermostats generally turn the unit on and off when the desired temp is reached but the fan itself (not the compressor or heat strips) typically operates in 3 modes, off, on or auto. check the fan setting.
Nov 15, 2014 | Honeywell TH5110D1022 Focus PRO 5000...
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
Jul 25, 2014 | Honeywell Focus Pro 6000 Programmable...
How do I change Honeywell pro 6000 to degrees instead of fahrenheit and I got stuck with the wiring - I have a red and white wire, got the heater going, but it wouldn't turn off - where do each of the...
google honeywell & see what you fined . maybe( honeywell 6000) there should be a number for you to call... alot of thermostats have numbers with it just incase of your problem , should be on the back of it or inside the box the stat came in...
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
Lost directions to program a thermostat
i have a pro 6000 t stat it shorts cycles any clues to change the off set
Nov 09, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
277 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
