Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore washer drain pipe siphon position
Please, a diagram of the above would be so helpful thank you nancy
    Problem Solver:
No my problem was with my kenmore washer...no problem really, just wanted to see a diagram of the height of the drain pipe in back. If you have such a diagram, could to email to me? Thank you irregardless. nanclau
Posted on Sep 24, 2008
My used Kenmore washer fills with water then the water level drops downto about the half way level in drum. I just bought it used and installed it yesterday. Could the water be siphoning out into drain...
It sounds as if it is siphoning out the drain pipe.You have to get the drain pipe up to the top of the washer and also be sure that the pipe is a little bigger than the drain hose or it will siphon. Hope this helps.
May 13, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series i installed my washer yesterday but im having a problem the water will stay in the tub of the washer it just rushes out the drain in the back washer what can i do to keep the water in...
Hello, Welcome to FixYa. The drain hose coming out the back of your washer must be placed in a stand pipe or wash-tub to the highest water level of your washer, otherwise it will simply drain/siphon out as quick as it fills. I suspect you likely have the hose lying on the floor or shoved into the stand pipe too far or too low in some manner. Let me know how you make out or if you require more help. Good luck and thank you for choosing FixYa. Please take second to rate the info I provided here today. Regards, Macmarkus :)
Dec 05, 2010 | Kenmore Washing Machines
Our washer fills and drains at the same time.
Hi, Based on the limited info I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far. If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, and if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon. Do you hear any motor operating while this is happening ? If you answered NO, this further support's the idea of the washer siphoning out the water it is supposed to fill with. Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. Thank's for coming to "fixya" and good luck. Macmarkus :)
Apr 10, 2010 | GE WJSE4150B Top Load Washer
Our kenmore stackable washing machine on the rinse and wash cycle is not filling up with water. the water keeps running out
Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Dec 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
My maytag performa washer continues to drain while filling, therefore never starting the rinse cycle. The drain pipe is in a loop position so I know it is not siphoning the water out and the washer seems...
how far does the drain pipe go into exit drain because this shoulh not pushed into pipe more than 6" and should have a air break and also the drain pipe should be above top of bowl line
Nov 19, 2009 | Maytag Performa PAV2200
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
Apr 09, 2009 | Kenmore Washing Machines
I have a kenmore 80 series washer and it won't fill up some times
It sounds like a siphon issue so nothing should be broken.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore washing machine will only fill partially and seems to be pumping out at the same time. What would cause this. Thanks, Jim
check and make sure your drain hose is as high as 2/3 hight of washer ,,, if not it will drain as it fills ,, also make sure the drain hose is free and not down in the drain pipe to far / larry
Dec 08, 2008 | Washing Machines
KENMORE 70 SERIES KEEPS FILLING UP
you have a drain hose problem the water is shiphoning out as fast as it comes in you need to raise the drain hose above the tub level
Mar 15, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 80series washing machine
You have a siphon condition. The water is siphoning out as it fills.
Make sure you only have about 6 inches of the drain hose stuck into the house drain and make sure there is an air gap where the hose goes into the pipe so air can get into pipe. If you have the drain sealed to keep water from backing out of it, you will need to get the pipes cleaned for the washer to work properly.
The pressure of the water going through the pump during siphon is not enough to turn it on the machine.
Post back if you need more help.
Oct 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
179 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
