Question about HP DeskJet 670c InkJet Printer
Printer only works after test page is printed
If I print a Windows test page, then I can go to another program and send a job to the printer. But! once that job is done, any further jobs will not print. The printer will pretend to print, but the page comes out blank, and the light blinks asking for more paper, which it will just pretend to print on again. In order to print, I have to restart the computer and print a test page first, and then it will work fine, but just for one job.
    Sergeant:
    Champion:
  • 341 Answers
Possible causes:
1. printer driver conflict to other program. Try reinstallation.
2. virus or spyware. check and clean
3. remove all other printers in the list.
Posted on Sep 24, 2008
I am printing documents to my HP LaserJet 5000n Printer and the printer's not responding. I've tried restarting it and it displays that it's processing a job before displays that it's ready.
Either a corrupted driver or possibly a bad network card or parallel port, depending on how you have it connected. Does the printer print test pages from the on printer control panel ok? If yes, try printing a different document from a different program or try the windows test print from the driver. If it prints the windows test print then likely you have either a corrupted program or file. If it will not print the windows test print then I would delete the driver, download the current HP UPD driver and install that.
Sep 24, 2015 | HP LaserJet 5000n Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
Printer shows ready, whenI send a print job to the printers it displays printing, but does not print. The unable to cancel or remove printing jobs.
Check if the printhead starts moving when powering on the printer. The problem might lie in the printhead electrical contact pints in which case clean it gently. Alternatively replace the print cartridge where at least black ink is present. If these are OK but it wont pull in the paper then the rollers might be jammed. If its a laser printer,check by changing the tober cartridge amd post the result as a comment.........sodeep
May 11, 2009 | Computers & Internet
Printer not printing
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Not working dtc550
Since the printer prints the test page from the driver, most likely the problem is with your Cardfive software. To test this, try printing a card on the printer from Microsoft Word or Notepad. Just remember to set your page size or you will get multiple cards printed. The Fargo printer is just a windows printer and may receive output from any windows software.
Aug 02, 2008 | Fargo DTC550 Thermal Card Printer
Continues printing pages
sound like u have setting problem with either the program your printing from or the driver. It could be set to print 2 copies of print job. If your using windows XP there a printer driver in there for the printer. If your using an older version of windows you can used HP laserjet II driver. HP always made there printers to be able to print with LJ II driver.
Sep 25, 2007 | HP LaserJet 6L Printer
HP DeskJet 670c InkJet Printer Logo
89 people viewed this question
Ben Johnson
