Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp Light Put a new lamp in metsubishi tv and the lamp light is still on how do i turn it off?
  • sarah1martin Sep 28, 2008
    I changed the Lamp in my MItsubishi 52 in rear projection tv and the lamp light is still on. It also keeps asking me if I changed the lamp and saying lamp has exceeded expected life. Every few hours the tv will shut off for about 10 minutes and can then be powered back on. Can You PLEASE HELP ME!
  • 927 Answers
Good Day;
The has at least two circuit boards that need to repaired (rebuilt), not counting the other two boards. I would recommend that you call an Authorized service Center and have them come out and give you an estimate. COST? Cost about $700.00 depending on your location.
Good Luck, big IRISH. PS The new ones are better.
Posted on Sep 28, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
My tv won't turn on. the power supply is good but the lamp light keeps blinking. Does this mean i need a new lamp
Yes,if the tv LED light indication the word "LAMP" on the tv bazel frame is lighting up or blinking.The tv old projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and used daily 4 or 5 everydays?Yes,than ur tv projection lamp life are ended.Yes,than ur tv need a new projection lamp.
Apr 26, 2011 | Samsung HL61A650 TV
I replaced the lamp after only a 14 months but it will not light up, then I put the old lamp back in and the lamp comes on momentarally but then shuts off and the TV never lights up. Why will the TV not...
Lamps last between 5,000-8.000 hrs Keep in mind every hour you play TV ,thats an hour lost on Lamp and its also possiable to receive a defective Lamp even new doesnt mean it works.
Lamp Fan if defetive can also prevent lamp from lighting. This happens to protect lamp from running and getting way to hot and therfore buring lamp up .
Ballast Board that connects to lamp is what turns the lamp on,if the ballast board is defective Lamp will not firer,meaning you either have bad lamp fan or new lamp is defective. Heres another Tip Sony had alot of problems with their Light Engines prices for that part range from $650.00 up to $2,799.00 depending on which light Engine you have? Since your TV is Still under warranty take it in quickly and be sure to ASK about warranty on YOUR Light Engine!!!
Jul 03, 2010 | Sony KDS-50A2000 50" HDTV
Replaced lamp on WD57731. green light turns on then a ornage light, under lamp blinks
Please put back lamp cover, the last plastic grille that were removed to replace lamp in TV.
TV sense that lamp cover is not either put back or not fixed properly so it wont turn On. Check lamp cover and problem will be solved.
Thanks.
Nov 14, 2009 | Mitsubishi WD-57732 Projection Television
Lamp light is still on after replacing bulb lamp
Try removing the filter cover on left side of chassis and cleaning the filter. I had the dreaded yellow/green blinking light , so I removed and put back the lamp (it was ok) and cleaned the filter screen and the light was out, tv came on...all ok!
Sep 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Red Lamp Light turns on
Red Lamp light shows that TV requires New Lamp.
Please always buy original Sony lamp for smooth run of TV.
Mar 15, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
