Question about Black & Decker D2030 Iron
Have to hold cord in or it shuts off
If push cord in and hold it, iron will work. Let go, light goes out.
I know it's a bit late, but I had the same problem, and fixed it in a similar fashion to kcquidproquo's answer. I have a blog post about it with pictures over at http://racingcow.wordpress.com/2012/05/13/black-decker-d2030-iron-repair/. Hopefully it will help someone.
Posted on May 13, 2012
4 Suggested Answers
  • 447 Answers
SOURCE: shortage in my cord
Time to change the cord!! And stop pulling it out of the socket by the cord, pull it out by the plug itself
Posted on Apr 12, 2010
SOURCE: D2030 Iron: Iron keeps shutting off...like auto-shut off is al...
OK... quick disclaimer. Me = not responsible if you break your iron, set something on fire or electrocute yourself. If you're not sure what you're doing, find a qualified person to help or trash the iron. Getting hurt isn't worh a $40 iron.
That said, mine had the same issue... in my case, was a break in the cord.
Before you do anything that follows, don't forget to drain the iron. You'll have a big mess if you don't. :)
Accessing the cord connections requires a security screwdriver. You can buy one at a hardware or electronics repair store. OR if you're chep like me, make one yourself by using a Dremel with a cutoff wheel to cut a notch in a thinner blade, flat blade screwdriver. Any cheap flatblade screwdriver will do (eye protection recommended since you'll be grinding metal).
Unscrew the two screws in the back. Once removed, the colored plastic cover can be removed by inserting a screwdriver near the tabs that hold the cover in place and prying a bit.
Removing the inner cover is a little trickier.
The handle under the power indicator light (the red one) has an upper and lower section. Squeeze the lower portion of the handle directly beneath the light pretty firmly. You'll notice a slight separation between the back section and the handle. The back section is what you'll remove. I removed mine by squeezing the handle and pulling the power cord straight backward (I know that sounds odd, but it was the easiest way to get some leverage, plus it's already broken, remember???) Don't pull super hard, but firmly enough to separate the back panel from the back of the iron.
Once the back cover is removed, it's a pretty simple cord change. As there are a few more wires than some people are accustomed to, I recommend writing down the wire combos so you can reattach everything as it was.
If you have difficulty removing the crimped wire nuts (the plastic covers), you can use a pair of pliers to squeeze opposite the crimp and they'll open up enough to allow the wires to slide out.
From there, reassemble... opposite of the disassembly order.
Mine worked perfectly after this quick fix. Hope yours does too. Good luck and be safe!
Posted on Mar 06, 2011
SOURCE: While ironing the power goes off and on , if I
Hi am having the same problem can it be fixed
Posted on Apr 10, 2011
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Display light does not stay on when I begin to iron; The #1 acrylic flashes off and on when the light is on.
Depending on the models, most irons only have the light on when its heating up and when the thermostart switches off it cut off power and hence the light goes off.
Jan 13, 2011 | Black & Decker D2030 Iron
May 18, 2010 | Black & Decker D2030 Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
Shortage in my cord
Apr 12, 2010 | Rowenta Powerglide DE011 Iron with Auto...
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Power won't come on
You have a short in the cord. If you knew where the short was, you could possibly repair it. However, I would strongly suggest buying a new iron. An iron is an appliance that can burn your house down even when it's in GOOD working order. You should be able to buy a decent iron for around $30, and I would say the peace of mind alone would be worth it. Hope this helps,
Chad
Oct 08, 2008 | Rowenta Professional DE880 Iron
Iron not staying on
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jun 27, 2008 | Rowenta Professional DE880 Iron
Black & Decker D2030 Iron Logo
421 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
