Question about HIP Cossacks: Back to War for Windows
How to fix the color on cossacks back to war on window 7
  • 5 Answers
    New Friend:
LOL.. I'm glad I don't need to rely on a forum like this to help me out with computer problems. None of ya'll know what you're talking about. Running as administrator has nothing to do with drivers, where did you hear otherwise? Or did you literally just make it up. To the guy who said the 'only option' is to run the game in compatibility mode, no.Compatability mode has nothing to do with, and someone had already even posted a link to the patch that fixes it. I don't understand why people need to dribble a bunch of non-scense out of their brains in an effort to answer a question when you don't actually know the answer.
It's like if the battery died in your car, so you call roadside assistance and ask if they can give you a jump. They say no, the only way to fix it is to buy a new oil-pan. Does that sound moronic? That's how you sound.
This place is literally the worst place on the internet.
Even though It's far too late, the Windows 7 patch linked to in another reply worked for me after having the same problem. I'd recommend next time you just look it up on Google yourself, the internet is unfortunately crawling with derps who don't know what they're talking about.
Posted on Aug 20, 2015
4 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: i have windows 7 installed on my pc.i installed
Well, try this, we call this "compatibility" mode, most programs can be run on windows 7 with this trick.
I assume your Cossacks II Napoleonic Wars icon is on the Desktop,
Right-click the Icon (game's icon), select "Properties" and click "Compatibility" tab, select "Run this program in compatibility mode for" click the "Windows 95..." and select "Windows Xp (Service pack 2)", click "Apply" > "Ok" and try again.
If even after doing this, the game can't be played, then there's no option. The fact is that, this game is made to run on system with Windows xp and earlier version, but somehow if fortunate, it's possible, not will all software, some may work, some may not.
Good luck.
Thanks for using FixYa.
Posted on Aug 12, 2010
SOURCE: Cossacks European Wars on Windows 7
just installed cossacks ew and changed video file name as suggested and it worked the problem i have now is the graphics have a yellow,red and blue dotty shaddow where there shud b a solid black shaddow, game is playable but its just very annoying!!! pls help im running windows 7 btw
Posted on Aug 19, 2011
DrewPalmer04
  • 325 Answers
SOURCE: I've installed Cossacks{the Art of War} in Windows
Right click on the program. Then navigate to compatibility, then select the compatibility operating system the game is supposed to be played under. Also, after you select xp sp3 or whatever you need go ahead and check the box that says "run as administrator." This will run the game under the proper drivers needed for that game to run properly.
Please rate if this helped :)
Posted on Mar 31, 2011
How to play Cossack European Wars
I would need more info about your system
if its windows 7/8 set the compatibility to windows xp service pack 3 and run the program as admin
May 08, 2013 | Strategy First Cossacks: European Wars for...
I dont know how to run cossacks eur. wars on win7....how?
Windows Vista or Windows 7, will have problems running some older versions of applications, just because so much has changed under the hood from Windows XP days. Thankfully there is a compatibility mode that can be easily set per application.
To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu. THEN select your compatibility tab, You can choose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can't get things working. If you are trying to run a video game, you will often need to choose "Run this program as an administrator". You'll have to play around with it, but most likely you can get your application working this way. Also, you will be able to make a selection for windows VISTA which is backwards and forwards compatible with WINDOWS 7
Jan 12, 2011 | Strategy First Cossacks: European Wars for...
I've installed Cossacks European Wars onto my laptop which has Windows 7. However, when I try to run the game I get a dmcr.exe error. I've looked at solutions online which told me to change 'Video' to...
1- download a direcx and install it (i put a link for you)
http://www.softwarepatch.com/windows/directx.html
if it doesn't work:
1- go to control panel from start menu.
2- select windows update.
3- select check for updates.
Jan 10, 2011 | Strategy First Cossacks: European Wars for...
I can't not play cossacks 2 napoleonic wars in windows 7 you have any solution?
The Game doesn't play because of totally different work environments than it has been designed to. Here are some solutions:
1. Rename Video folder in the game.
2. Right click on the program. Then navigate to compatibility, then select the compatibility operating system the game is supposed to be played under. Also, after you select xp sp2 and check the box that says "run as administrator".
3. Download this patch from:
http://www.downloadsource.net/v/11290/
Nov 02, 2010 | CDV Software Cossacks 2: Napoleonic Wars...
I have windows 7 installed on my pc.i installed cossacks II napoleonic wars properly,and when i try to start the game,i get information that the game can run only on older versions on windows (95,98 XP )....
Good luck.
Aug 12, 2010 | CDV Software Cossacks 2: Napoleonic Wars...
yo change folder name Video -> video1. You will succeed. :D
Jan 23, 2010 | Strategy First Cossacks: European Wars for...
HIP Cossacks: Back to War for Windows Logo
13,282 people viewed this question
Top HIP Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a HIP Video Game Console and Game Expert? Answer questions, earn points and help others
