I have a rca model # m50wh74s......i have sound and can control the volume and channel but there is no picture.....the blue power light flashes.....when it was working right the light was solid
  • Anonymous Nov 17, 2008
    can control sound and channels but no picture
  • 5,138 Answers
Replace Deflection board cost 77.99
Posted on Sep 24, 2008
CAN I USE A RCA UNIVERSAL REMOTE CONTROL FOR MY LCD COLOR TV MODEL NUMBER WF20L6
Yes the RCA universal should operate the normal functions like volume + & - , changing channels, power on & off. It may not operate certain other functions like picture in picture, on screen caller ID things like that. You should be able to get a stock replacement remote from the manufacturers web site.
Aug 01, 2016 | RCA Televison & Video
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
I have an RCA 32" LCD HDTV/DVD Combo model 32LB30RQD it has power, but no picture or sound and no turn off the blue power light.
Probable defective power supply board in the set. ebay RCA model # for replacement power board. Replace board
Dec 29, 2014 | RCA Televison & Video
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Have a RCA M50wh74s replaced the bulb....blue light blinks 5 times again and again eventually a steady blinking all blue light bulb in correctly, door closed correctly, any suggestions and I have sound.
Bad Caps on the AC IN board? I would visually inspect the caps on the AC IN board for any sign of swelling or doming on top. They should be perfectly flat.
Aug 20, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA DLP Model # M50WH74S Problem: Replaced blown lamp, when plugging it into AC, blue LED lights up right away for 2 or 3 seconds, then shuts off. Waited for a few seconds, and relay will click on and...
The blue led dies because the power source dies: it detects a big short on one of its outputs and shuts down to protect itself automatically. Since apparently it's a very big short and you just had to replace the bulb then the faulty part is the ballast board (the one that powers the bulb): when the bulb failed it has generated a power surge that fried it.
Replace the ballast and verify the power source board: if you're really unlucky when the ballast got fried it has in turn damaged the power board.
Oct 17, 2010 | Televison & Video
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
429 people viewed this question
Top Televison & Video Experts
