Changing the lamp on a DLP LCD tv
Do you recommend trying this on your own?
  • azamh66 Sep 25, 2008
    I did check the manual but there's nothing there.
    Its a Zenith M52W56LCD
  • 203 Answers
Most definitely! The lamp is a consumer replaceable item and your owners manual should have instructions on how to complete this task. If you don't have your owners manual and more post your model number and i will get you some instructions on how to replace it!
Tim Nolan
Posted on Sep 24, 2008
Hi all ~
I have a 4 year old Zenith DLP 41" TV and have recently noticed a discolored circle in the lower middle of the screen. When the TV is on but with a black screen the circle appears blue, but when the TV is on a channel it appears yellow. Is this something I can fix or should I start looking for a replacement?
Posted on Aug 23, 2009
You will need the DLP chip replaced. I do not recommend trying this on your own on a Mitsubishi. You need a technician who has extensive Mitsubishi experience to replace that chip(if it is available for your particular model) If the chip is not available for your particular model, it means replacing the light engine.For that cost I would update to a LCD or LED TV & come out ahead.
If you want an idea what it costs to replace the DLP chip (if avail for your unit) contact a local servicer & see what they can quote you over the phone. Be sure you are sitting down.
Considering the age of your unit I would be looking at an LCD or LED flat screen.
Jul 24, 2014 | Mitsubishi Televison & Video
Replaced dlp chip
The yellow blinking light generally means that the lamp cover is open. You may have accidentally jarred the lamp while changing the DMD chip, and the lamp safety switch is not engaging. The first thing I would try would be to re-install the lamp and make sure the cover is on correctly. Let us know if that solves the problems. Thanks.
Feb 10, 2014 | Mitsubishi WD-73733 73" HDTV
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
U can replaced the DLP tv projection Lamp ur self.Try website like in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like, to buy a new DLP tv projection lamp.
Oct 15, 2010 | Mitsubishi WD-52631 52" Projection HDTV
While tv is on, at times screen just blacks out ...then comes on remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
The power will not turn on and the power LED is flashing red.
PT-50LD54 is an LCD rear projection TV with a consumable bulb that wears out normally after 2-5 years of use.
Most likely you need a bulb. That is first step in any troubleshooting for that tv. Check out Panasonic Gallery to identify lamp and replacement bulb.
Changing bulb involves removing the lamp assembly and replacing the bulb in the lamp assembly. Like doing a puzzle. Requires philips screwdriver, pliers and patience. Don't have jam on your fingers when you do it.
Apr 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
No, your DLP does not need the annual cleaning as your old projection tv did. The rear projection used high voltage, 35kv, which attracted dust and smog. I would recommend to have your DLP cleaned when your LAMP goes out. Your lamp should last 2-3 years, then I would call a factory authorized service dealer to replace your DLP's lamp and have them do the cleaning at that time. I do it everyday as a in-home service tech.I hope this help.
Jun 11, 2008 | Televison & Video
Need a replacement lamp for a Protron 26" LCD TV
This is an lcd tv. It does not use a lamp. dlp tvs use lamps. You have fallen into the trap many others have. I am a servicer and I have found there are absolutely no parts, no service manuals, nothing at all available to repair any Protron set. You save some when you buy, but when they break, throw it out.
Feb 03, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
