Question about Denon AVR-2400 Receiver
Tuning speaker system denon avr 2400
I installed a 100 w sub through the 5 channel preout but am not satisfied with the sound. the dealer of the sub demo the same sub in another system and was dynamic. i cant increase the sub vol. control panel show 0db but does not go up or down. i can adjust other speaker vol . it is only activated when dolby pro is on otherwise every other surround is 0 db. i dont have a manual. please help. thanks
    Sergeant:
    Champion:
  • 341 Answers
You need to check on the operation of your receiver regarding the use of the subwoofer output line. If it does not satisfy you, better get a better receiver or A/V control pre-amp system with lots of features in the subwoofer circuitry. Google (internet) might help you with your specific model.
Posted on Sep 24, 2008
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
I just received a Denon AVR-4308ci receiver. I have two passive subs in my system. The receiver only has one powered output. Since I am not using the surround back speaker outputs can I use these for the...
Sure, if you want to hear Surround Back program material coming from the subs without midrange or tweeters. (Sarcastic) Of course, the LFE program material will still be going into a black hole somewhere.
Run the subs in series with each other -
Sub Amp negative to 1st speaker negative;
1st speaker positive to 2nd speaker negative;
2nd speaker positive to amp positive.
Run the speaker level adjustments routine and enjoy.
Just for giggles, try what you were thinking about. You won't hear much from the sub(s) unless you programmed the Surround Back channel as full-range and then have something like the Apollo 13 launch for program material. Normal audio won't send much low-frequency material to those channels. The optimal place for subs is on the LFE or sub channel.
Nov 17, 2009 | Denon AVR-1507 Receiver
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Have he KEF 2005.2 Speakers and I cannecting to the DENON AVR 2802 Amp. All Satellite speakers sound OK but there isn't ny sound from Subwoofer. I don't get he System Setup display on the Amp screen...
Run a phono cable from the monitor out on the back of your amp to the tv then go to that input on the tv and then go to the setup menu on your amp ,also make sure you have the sub cable pluged into the sub preout and not the 6channel input.
Hope this helps.
CABLE GUY.
Jul 11, 2008 | Denon Audio Players & Recorders
Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Aug 27, 2007 | Denon AVR-4800 Receiver
218 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
