Question about Amana Kitchen Ranges
Amana electric range - light but no heat
My range still has oven light, surface and oven indicator lights and clock working, but none of the range top or oven elements heat up. The first time it happened, I turned off the electric power for 10 minutes, then turned it back on and that fixed it. Two days later the same. Once more the next day. After that, turning the power off and on didn't work except to turn on the clock. If I tried to turn on an element, I got the indicator light but the element stayed cold. I was sure it was the electronic control unit and ordered it. I made sure it really was a match for the original part and that connections were exactly the same. Unfortunately replacing the control unit has not fixed the problem...it's the same. Any ideas? The range is 8 years old and I'm not ready to give up on it yet.
  • rablef Sep 24, 2008
    Actually I shut off power to the range by shutting off the 220 breaker for the range in the breaker box. Then waited 10 minutes and turned it back on there. Several times that worked and I got the range to work again. The circuit breaker never tripped on its own. That's why I thought the problem was in the range.
  • rablef Oct 04, 2008
    mca0824, I think there is a misunderstanding here.
    First, I must say that you were right and the problem was that I was only getting 110V. Once the defective circuit breaker was replaced the range was fully functional again. So thank you for your help. I was glad to again be given the opportunity to change the rating to FixYA
    In your reply, you suggested first checking the breaker. Knowing that the breaker (two 40 amp breakers tied together) had not tripped by itself, I figured that the problem would be elsewhere. My reply to you was in the hopes of getting a further response. The problem was not fixed, I felt frustrated, but I was still required to give a rating at that time.
    Second, after a couple of days with no more responses, I checked the voltage at the stove terminal, and lo and behold, one leg had no voltage. So apparently this double circuit breaker was functioning only partially, without tripping, and I was "fixing" it (but only temporarily) by turning it off and on. I thought that only worked for computers, not old fashioned electric switches. But you put me on the right path and again I thank you.
    Finally, I am surprised at your sarcasm. My rating was "thanks for trying" , not "thanks for nothing". If that is considered a BAD rating then maybe the ratings should be explained better to the public. My wish for you is to feel less insulted when you do not get the appreciation from your customer that you feel you deserve. Sometimes people are distracted by their many problems and do not always express appreciation as they should (and want to). Others are self centered and give appreciation to no one. You should not let this detract from pride in your profession and the personal satisfaction of a job well done.
  • 172 Answers
Hi rablef,
I would recommend you check your fuse or breaker box for a blown fuse or tripped breaker. If you are only getting one leg of your 220 volts the you will have the problems you have listed. If you have no breaker or fuse problem you should then check your range cord for possible shorts or hot spots. Then work your way to the terminal block on the range. It definately sounds like you are only getting 110 volts to your range. I hope this will FixYa.
Good luck, Mike
Posted on Sep 24, 2008
  • Michael Anderson Sep 30, 2008
    Maybe one side of the breaker was tripped and by resetting the breaker you solved the problem just like I stated. Thanks for the bad rating, I will be sure to help you first in the future.
5 Suggested Answers
  • 74 Answers
SOURCE: Surface element doesn't work
When an electric element doesn't work, either it isn't receiving electric power or it's likely that the element or receptacle it plugs into is faulty. Check the other elements. If none work, the circuit breaker has probably tripped. Reset it at the electric panel. If this reoccurs, call an appliance repairperson. If just one burner isn't working, try to pinpoint the source of the problem-- likely a bad element/burner or a problem with its connection receptacle. In some cases it's the switch or the wiring. To replace a bad switch or repair the wiring or replace the receptacle, call an appliance repairperson. A burner that plugs into a receptacle is easy to test. After turning off the range's power at the main electrical panel, just unplug the non-heating burner, plug it into another working receptacle, restore the power to the range, and test it. If the burner works, you know its original receptacle is probably faulty. If it doesn't work in the good receptacle, the burner is bad and should be replaced. Buy a replacement and simply plug it into the receptacle. When you remove the burner, look for burned wires or a charred receptacle. Check the receptacle or terminal block to see if it's cracked, loose or looks burned. If you notice any of the above signs, replace the faulty component, too. If the male burner prongs are corroded, always change the female receptacle it was plugged into. A flip-up burner requires a little more work. After turning off the power, tilt up the burner, unscrew the small screw that holds it, and then slide it out. Disassemble the insulator block by prying off the clips. Then unscrew the wires from the element, replace with a new burner, and reassemble. To test a burner with a multi-meter: First remove the burner from its receptacle, as discussed above. Set the multi-meter to the Rx100 setting (or, for a digital meter, to [omega symbol] or k[omega symbol]. With the red lead connected to the positive jack and the black lead to the negative jack, touch the black probe on one of the heating element's terminals and touch the red probe to the other terminal. The needle should jump from the infinity reading to the right, indicating a properly "closed" circuit. If it doesn't, try the probes on a different part of the metal contacts. Still no reading? Touch the two leads together to make sure the meter is working (the needle should jump). If it works, there is an internal break in the element and it will need to be replaced. When you're finished, turn the power back on.
Posted on Jan 18, 2006
fridgetech
  • 473 Answers
SOURCE: From where do I access the lower oven element on a Amana ACF4215A
There should be two screws at the rear of the bottom panel inside the oven. Remove those and lift out that panel. The element is under there. If there is not enough wire to pull thru you may have to disconnect and reconnect the wires to the element from the back of the oven by removing the back panel. Hope this helps.
Posted on Nov 18, 2008
Maytag317
  • 1136 Answers
SOURCE: Surface Burner not heating
HI, The wire that comes with the receptical also comes with wire nut and instructions. It is only a two wire receptical so you will not ned a schematic. Alos, make sure the ends of the element are clean (no burn marks) or it will ruin the ne receptical in time. Can I help further?
Vic
Posted on May 16, 2009
Maytag317
  • 1136 Answers
SOURCE: 0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
Posted on May 17, 2009
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Clock works fine, but surface elements do not light up or heat.
it sounds like you are only getting 110 volts to the stove.
have someone that knows a little about your breaker box. check the breakers
you may only need to wire it right or may need to add another breaker.
should be an relatively cheap fix.
good luck remember electricity bites!
Sep 13, 2012 | Frigidaire FPES3085KF Stainless Steel...
Electric range not heating
You should check your Hi Limit thermal switch part#74008715 you will have to remove the oven from the wall to access this part.
http://www.on-timeappliance.com/ovenrepair.html
Mar 24, 2012 | Amana Kitchen Ranges
We have a Hotpoint RB787 Electric Kitchen Range. We experienced electrical issues/ power surge and now the oven part of the stove does not work. top still works and only indicators for the top burners...
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
Jan 08, 2010 | Hotpoint RB787 Electric Kitchen Range
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
GE JBS55W0J3WW Electric oven will not heat up. None of the 4 elements on the top or the bake or broil elements will power on. The clock, oven light, timer, hot cooktop and oven on lights all power on as...
Check to make sure you have 240v at your receptacle. Lights, clock, timer, will still work with 120v, while the elements need 240v. Start by checking your breakers to make sure that one of the two breakers feeding your oven hasn't tripped.
Apr 13, 2009 | GE JBS55 Electric Kitchen Range
Maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Oct 06, 2008 | Maytag MER6772 Gemini Electric Kitchen...
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
May 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
1,028 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
