Question about IBM ThinkPad T43 Notebook
Problem with video card (I think) in T43 Thinkpad
My T43 has a dark screen. If I shine a flashlight close to it I can see the screen but not enough to do anything. I think it may be the video card. Where is it located? My husband will change it out for me if we can find out where to go to pull it out.
Thanks for any help you can give.
Jessica0238
The back lite button sticks down get a needle and try to lift it if this brings the display back on,then the fault is that the spring that returns the switch has broken away from the fixing
the solution is to remove the button or replace the hole top plastic fascia as that is ware the spring has been bonded to
i removed mine and set the settings to shut the monitor down after 15mins
hope this helps
Posted on Nov 09, 2008
    Sergeant:
    Champion:
  • 341 Answers
It is a LCD backlight problem. The usual cause is either a bad high-voltage driver or a bad controller signal from the mainboard of your computer. You need to consult a service technicain for your machine.
Posted on Sep 24, 2008
Black screen
Here is a fast test for the inverter in the display. Take a small flashlight and shine it in to the bottom right corner where the windows start button should be. While shining the light in try looking at the screen. If you can see the Start icon then the inverter PS or the FL tube in the display is bad. The least expensive fix is to replace the Inverter. There exist detailed instructions for the disassembly of the display panel as well as sources for the part itself. If there is further problems contact back later.
Nov 26, 2013 | IBM ThinkPad T43 Notebook
Ibm thinkpad t43 backlight issue
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 04, 2012 | IBM ThinkPad T43 Notebook
Hi, I have a T400 and when I trun it on the Thinkpad black screen appears and does not change. Please can you help
Does it seem like the laptop is running except the display is black? Do you think it booted all the way except the screen is black? Do you hear fans running, disk drive spinning?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 09, 2012 | Computers & Internet
WHEN A SYSTEM IS ON BUT NOT BOTHING ON THE SCREEN
If it's a desktop try another monitor. If the other monitor works, then the original one you were using is bad. If the other monitor does not work then most likely your video card is bad.
if it's a laptop take a flashlight and shine it on the dark screen. If you look real hard you might barely see the icons on the desktop. If, so then your LCD Inverter is bad. If you don't see the desktop with a flashlight, try using a external monitor. If the external monitor displays your desktop, then the video card is good, but more than likely the screen will need to be replaced.
Mar 26, 2012 | IBM Computers & Internet
My ibm thinkpad notbook pc have not display ...plz give some solution
shine a flashlight on the dark screen when the unit is powered on and see if you see anything. your backlight may be blown.
Dec 02, 2010 | IBM ThinkPad R51 Notebook
I have a thinkpad T43 my screen keeps going in
enter the bios and go into advanced settings(if i remember right its page two) select lcd screen for maiin and secondary display and it should stop it reverting to the external display(which is the reason you have to hit FN +F7)
Dec 29, 2009 | IBM ThinkPad R40 2722 Notebook
Vertical lines on thinkpad T43p screen.
You have identified the fault is the video card, I am in agreement. The fault is on the motherboard and a replacement motherboard is the only fix. This may not be a cost effective solution, I would recommend you put your money towards a new laptop.
Jun 27, 2009 | IBM ThinkPad T43 Notebook
Ibm thinkpad t43 freezes up
i think for internet browsers500 mb ram is not sufficient ...................so increase ur ram minimum to 1 gb
Jun 24, 2009 | IBM Thinkpad T43/p Notebook
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
222 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
