Question about Mitsubishi VS-60609 60" Rear Projection Television
Mitsubishi VS-60609 60 in. I get sound but no picture. Just a red, green and blue lines in the middle of screen. Looks like a hour glass shape.
  • maximumsone Sep 25, 2008
    I do not know how to use a meter or solder. I am going look for a good repairman. It think it is a vertical circuit. I start having problems with my tv picture size first. The TV picture would go wide and back normal size.
  • rich15sports Jan 25, 2009
    what wuold i need and the steps i need to fix....richard
    Novelist:
    Champion:
  • 203 Answers
That sounds like a bad vertical circuit. Do you know how to use a meter and solder? If so we can troubleshoot otherwise you will need to call a repairman. A good repairman should run you $300-$500 to repair this. Let me know what you would like to do!
TIm Nolan
Posted on Sep 24, 2008
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Screen role red and green wavie lines.
Hello dctc1,
Looks like there is a problem with the convergence IC's. You will have to replace both of them. I would also look for busted capacitors around the IC's.
However, if you are not familiar with TV repairs, I would advise against opening up the set. Best get a service man to come and diagnose/repair the set.
Hope that helps!
Please dont forget to rate or "Accept" the solution if it helped you in any way, or leas you to a fix.
Thank you for using FixYa!
IrishDruid
May 18, 2008 | Mitsubishi VS-60607 TV
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Green and Blue are stuck as thin shape up the middle of screen
You need to replace both convergence ICs numbers STK392-110 they are located on the far left side attached to the large heat sink. You can get replacement ICs at the following link and they provide free instructions with pictures so you can do the repair yourself in about 45 minutes from start to finish. heres the link.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Bowing in the middle like an hour glass
about the zenith it seems you have the flyback transformer malfunctioning - try to change it - delfo
Mar 22, 2008 | Televison & Video
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
206 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
