Question about Boss DVD9800B Car DVD Player
Boss DVD9800B no sound from speaker wires
I have a Boss DVD-9800B and I have no sound coming from the speaker wires. I can hook up an amp to the RCA's and have sound coming from them. Boss said it would be $640 to send it in and have it repaired, which is out of the question. I'm an electronic tech and could easily do any necessary repairs myself. Is there a detailed manual that it could just be a setting causing this, or any tips what to check internally? Thanks in advance for any help.
  • sanoma98 Mar 17, 2009
    When i put a cd in all i hear is static
Yeah I took out my Boss out my Car sold to my friend before I sold it I check it
now he saying there's no sound what could he had done for no sound not to be coming
out through the speaker wire's.
Posted on Nov 05, 2010
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
My dvd player is a boss 9800b i can't see the image when the dvd disc is playing , on the screen there's a message ''parking'' the pink wire is parking, my car is a hyundai ,
the pink wire is to connect to the negative side of your park brake switch. if you dont know where it is see a licenced installer. hope this helps let me know how you get on.
Jan 26, 2011 | Boss DVD9800B Car DVD Player
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
Radio will not turn off when I turn the car off
do you have the red wire going to a switched (ignition) power source? (power turns off when the key is off)
Aug 23, 2010 | Boss DVD9800B Car DVD Player
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
The amp is hoocked up right and i still have a red light but the fan works what could it be
try hooking it up withut the rca cables and speaker wires hooked up. see if i works then
Oct 14, 2009 | Boss RIP-495 Car Audio Amplifier
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Boss DVD9800B Car DVD Player Logo
372 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
