Question about Sony KDF-E42A10 42 in. LCD Television
42" sony wega KDF-E42A10
When i turn on the TV it comes on, then goes off and the standby light blinks red 4 times. What does that mean?
  • Anonymous Mar 20, 2014
    There is audio but no video. Red light solid when turned off.
    Novelist:
    Champion:
  • 203 Answers
4 blinks is a fan error. I would take the back off and look to see if the fans that are visable are spinning when you try to turn it on. If you see one that is not spinning it needs to be replaced. If all the fans you can see are spining then there may be some fans that are hidden, in this case you will need to be able to use a meter to determine what fan to replace. Let me know what you find!
Tim nolan
Posted on Sep 24, 2008
I have a kdf-e42a10 tv no sound or picture red light flashes continuous
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 09, 2013 | Sony KDF-E42A10 42 in. LCD Television
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year ago....now when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
The power/standby light blinks red three times pauses then repeats on my Sony KDF-E42A10 TV... no power Thanks
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
Apr 28, 2011 | Sony KDF-E42A10 42 in. LCD Television
My parents have a Sony KDF-E42A10 42" LCD TV. They have audio, but no video. Screen is black. Do you think they need a bulb replacement?
Yes, if lamp has not been replaced in last 2-3 years then it is lamp problem. If tv does not shut down and its standby light does not blink in red then lamp is cause of problem, replace it to fix tv issue.
Sep 26, 2010 | Sony KDF-E42A10 42 in. LCD Television
Only comes on for a second power light blinks red 4 times, stops then repeats
4 times standby red light blinking is an error code that shows that Fan problem in tv. Check following possible causes of that problem in tv:
1- Fan 1-4 power is not supplied. (AGU board).
2- Fan caught wires or harnesses.
3- Fan connector is not attached securely.
Thanks.
Jul 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-E42A10
replace the lamp and you will most likely be good to go.
Mar 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
What the @*#@*#
The 4 blink fault code means one of the fans is faulty or the H4 module in the TV.
Jun 07, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E42A10 42 in. LCD Television Logo
308 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
