Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Pull string won't spring back in
It was working fine all day and the last time we tried to start it it would'nt go back in. I have it apart. Any way to fix it temporarily just to use for tomorrow until I can get new springs or whaever it needs?
  • 659 Answers
Rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
sounds like to me it just didnt wind itself up properly but without inspecting the unit I can only make assumptions try that and see if she gets her spring back into her.
Posted on Oct 04, 2008
I have a Yard Machines 28cc 15" Y28 trimmer. Every thing was fine until it stopped advancing string. So I tapped it on the ground and I got no advancement. Removed the reel and the string pulled off...
Clean everything very well, make sure spring is not hung in compressed position, you should be able to push button or head down and then pull on string and it should come out. Push again and it should pull out again, if not you will have to find reason why. The last time you changed string are you sure you wound it correctly?
Nov 25, 2017 | Yard Machines Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
I have a stihl fs 80, the starter cord will not retract after the first pull. The spring is still intacted but doesn't spring back when re-attached to weed eater.
One of 2 things come 2 mind, if the spring is still in tact it could be that the retract line might be slightly to long and forces the spring to over travel and lock up against itself. A simple test would be to pull the pull start to only 80%. If at 80% it retracts normally then shorten the pull string by a few centimeters . alternatively the spring may be over tensioned by a turn or two. to release pull the string out with the pull starter off the machine to about halfway, hold down the recoil to release the tension off the string and pull the string out towards you through the slot provided on the face of the recoil into a loop. Gently let the recoil slip one full turn at a time until there is just enough tension to pull the handle all the way back. if its too loose just revers the process one turn at a time. its not complicated, to do but can be tricky,
if DIY is not your thing, refer to someone better qualified,
Sep 05, 2012 | Garden
The pull starter on my Morrison BC260B S2 won't
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Feb 18, 2012 | Garden
String does not seem to feed automatically frequently have to take the spool out to re thread through the lottle holes
These things can be very sensitive with how the sting is coiled on the spool. Take your time and try to get it perfect. Look at the pre strung replacement spools for an example. also inspect the lever, usually under where the spool sits. Make sure its not to dirty and moves freely. After that when you want it to feed quickly pull and release the trigger a couple times. If you dont want it to feed the when you pull the trigger be sure to maintain how far you have it pulled back, then release it a little slower than usual. Lastly wait a few seconds before pulling again. If this doesnt work the lever may be worn out and defective. But they are super cheap and easy to replace.
Sep 11, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Bought mower used has nt been started in a while .when try the manual pull start the string does nt retract
sounds like the impeller on the underside of the starter mech is broken
Mar 06, 2011 | Garden
Pull string came off as I was trying to start it.
there should be three or four screws to the top of the mower where the string goes, after purchasing new pull string make sure you wind the spring when you re string, so that when you put the cover back on it will be spring loaded and in proper working condition
Oct 17, 2009 | Ariens Garden
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
218 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
