Question about Gateway CX2610 Notebook
Screen falls back
CX2620 notepad - I've had it for 2 years and now the screen will not stay up.. It is loose and flips back.
  • Anonymous Dec 02, 2008
    The screen will not hold itself up. It either falls completely back or shuts forward.
    help!
  • 3 Answers
Go to www.mundocorp.com and buy new hinges. Thye are $49 US for a pair.
Posted on Jul 25, 2009
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
When i move my Gateway W323-UI1 it freezes
that's BAD! it sounds like there's something loose inside your laptop. the only thing i can suggest is flip it over, unplug the power cord, remove all the panels from the back and the battery and shake it and see if anything falls out. while you're in there make sure that you ram chips are securely installed.
Jan 31, 2012 | Computers & Internet
The screen is staying upside down when it starts up
Press "CTRL + ALT + arrow key"
Arrows:
Left - Rotates screen to the left
Right - Rotates screen to the Right
Up - Rotates screen to back to normal
Down - Flips screen
Aug 22, 2010 | Dell Inspiron 1501 Notebook
Loose Monitor on a HP Pavilion ZV6233nr Laptop
It seems that some screw that was loose is now totally out of socket. The latch assembly might be disbalanced due to that. To me it doesn't seem to be a broken latch.
Apr 04, 2010 | HP Pavilion zv6233NR Notebook
Screen blackouts & graphics mess up
I have experienced the same problem with an Nvidia graphics card. From what I could tell, it was an overheating issue to begin with, which quickly turned into a damaged graphics card. What I ended up doing on my desktop is opening up the side of the case, and decreasing the graphics load on the card. I still ended up having to replace the graphics card. I would suggest upgrading to windows 7 as well, even if you have driver problems, the upgrades in the OS seem to handle the errors much better and recovers without the severe color / rendering problems like XP did.
If you are confident it was not an overheating issue that started this, please boot your computer into safe mode, completely uninstall the graphics drivers, reboot into safe mode and install the drivers again. Most Operating Systems tend to stay 'sick' from old drivers even when you're using new drivers, so the best way to do it is completely get rid of it, and put it back in.
Dec 02, 2009 | Gateway Convertible CX2620 Notebook
Toshiba satellite laptop screen won't stay up
there are screws on the hinge that would require tightening they have come loose there are alot of little teeny tiny screws in those laptops so it is recommended that you take it to a technician
Mar 07, 2009 | Toshiba Satellite 2405-S201 Notebook
Screen does not stay up
Yes. Simply remove the hinge cover (above the keyboard). If you see a small notch on either side, you'll need a small screwdriver to pop it off by prying it and listening for the pops. It's scary the first time, but don't worry, it won't break, it's meant to be a beehatch to get off :P. But be sure your lappy is turned off, battery removed, and that the screen is as open as it can be before doing this 180 degrees!
Once it's off, you should be able to see the hinges, if they look loose, tighten them with jewel screwdrivers.
To put the cover back on, put it back on the opposite direction you took it off, and at a slight angle, press down moving from one side to the other until you hear it snap into place. The very end might take some leverage and muscle.
If this doesn't work, your hinges are getting old (and believe me dell ones are ****) and wearing out, and unfortuneately, only a book or smth can help you then. The only other fix is getting some dell lcd bezel hinges and replacing them (or sending it away to get it fixed), although it will be fixed for sure then.
Jan 03, 2009 | Dell Latitude C610 Notebook
Gateway CX2620 Swivel Screen Laptop
This is the worst solution I've ever heard. This guy is trying to steer you wrong I'm pretty sure. There is zero point in removing all the screws from under the batter/ zero point to removing the area around the power button. Absolute BS. The only part to remove is the part just above the top of the keyboard (silver strip with some black). Then by removing that you can pry the swivel black plastic cover off. Whatever you do.. do not follow Scott's writeup here. I'm telling you. It's sad it's stayed up so long.. so had to warn.
Dec 10, 2008 | Gateway Convertible CX2620 Notebook
Gateway Table PC Cx2620 Screen Wobble
Unplug and remove the battery pack for safety. DOn't want any shorts to happen. With the laptop open, gently pry with a very small blade the plastic cover at the front of the swivel and remove. It is in two pieces...front and back. It is OK to leave the rear half in place. Once removed you must close the laptop again. You will now have access to the screws on the hinges. Use a small Robertson screwdriver to tighten the screws. Snap the cover back in place....Voila!. IF the screws are broken (like mine were) remove all the good screws, gently lift and move the screen slightly forward, remove the broken screws with some needle nose pliers. Reassemble with new screws. I found some screws at the local computer geek shop in his selection of random screws. THey are quite tiny. CHeck Future Shop if they are in your area as they deal and repair Gateway so you may have a better chance of finding some screws that work. Good Luck.
Nov 18, 2008 | Gateway Convertible CX2620 Notebook
Gateway CX2610 Notebook Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
