My gas fireplace turns on for a minute or so. then the flames turn blue as if lacking oxygen, then go out completely.
    Scholar:
  • 147 Answers
Blue is a good flame.. Yellow, lazzzy flame is lack of oxygen. When the main flame comes on, it may be pulling the pilot flame away from the thermocouple..
Posted on Sep 24, 2008
My Mr. Heater 10,000 BTU Natural Gas Blue Flame Vent Free Heater #VF10KBLUENG keeps going out soon after it is lit.
Yellow flame indicates insufficient air is being injected into the mixing chamber - air hole blocked or restricted maybe.
Yellow flames indicate a general lack of oxygen and also a yellow flame is dangerous as it is producing high levels of carbon monoxide.
Dec 26, 2017 | Mr. Heater Heating & Cooling
Can anyone tell me why my direct vent fireplace flame looks like its in a wind storm. The pilot blows out as a rexult
Looks like too much yellow in the flame. That is normally caused by the mixing control on the gas feed tube being too closed. Trace the tube from the burner .....back toward the gas feed line....until you find the slip ring that controls the amount of oxygen that is mixed with the gas. Open is a small amount and light it. You should see a bit more blue color. If that does not work, continue to vary the adjustment until the flame burns correctly. The pilot should never blow out unless the outside air feed is too large. You can try blocking it a small amount to see if the smaller amount of outside air corrects the problem.
May 16, 2014 | Home
GAS FIREPLACE SOMETIMES TURNS ON AND SOMETIMES NOT. ALSO, IT CAN BE ON AND THEN THE FLAME GOES OUT BUT A FEW MINUTES LATER COMES ON. SUGGESTIONS?
This is a typical situation for a warn Powerpile generator. Your fireplace works by this generator generating heat from your pilot flame and converting it to less than 3/4 of a volt or 750mv. Your gas valve will eat up half of this electricity when running. So when you Powerpile gets warn it might only generate 400mv and when the gas valve turns on will bring it down below 200mv. This will start to drop once the main burner turns on and once below 150mv is no longer able to power the gas valve resulting in the main flame to go out. Minutes later the generator will build its power up again and repeat the cycle. The generator looks a little thicker than a crayon and has a red and white wire coming off it. They are easy to change but the tight spaces on a fireplace can make it very difficult.
Nov 02, 2013 | Heating & Cooling
My gas log fireplace runs for 2 to 6 minutes and then quits on its own. It is 10 years old. Any suggestions?
Look for a flame sensor, It is a wire that is has to sit in the path of the flame. IT is gets dirty and can cause this. You can clean it with scotch brite pads
Feb 28, 2013 | Home
I have a jotul gas heater pilot lights turn on valve flame starts the dies out
This is often a result of insufficient oxygen to allow combustion.
Check your venting for blockage.
Feb 04, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Fireplace will start but shuts off in about 30 seconds
Here's a few things to look for. After you light the pilot and turn on the burner, look at the pilot flame. Is it still a strong blue flame and it is still heating the thermocouple? If the pilot flame is a lazy yellow, it may not be able to keep a good enough flame on the thermocouple to keep it hot. The solution? Turn it all off and let it cool down. Take a can of compressed air, like you use to clean computer keyboards, and using the attached straw, blow out the dust or spider web that's partially blocking your pilot orifice. Where the pilot flame is usually lit, blow right down that flange, as well as through the air hole that is on the side of the pilot assembly. If you do it right, the pilot flame should be a nice and strong blue color. Another thought. Is this a vented or unvented fireplace? If it's vented, make sure it has the oxygen it needs to burn by checking for blocked vents or opening a closed fireplace fume above it.
Douglas
Nov 19, 2010 | Desa International CGCFTP Compact Heater
Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
Jan 02, 2010 | Heating & Cooling
Fireplace will not start. I have not had it lite since last winter. I turn to pilot and wait then hit ignite. I get a spark but the pilot light does not light.
your line mite be stopt up get a mach and turn on you gas and see if i lights up if it dont your eather out of gas or your gas holes whare the flame cums out is stopt up
Dec 16, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Blue flames on top of stove now more yellow than red
Have it checked out by a QUALIFIED gas person!! Don't screw around with gas unless you want to wake up dead due to carbon monoxide poisoning or an explosion!!!! Gas is NOT a forgiving task-master.
Apr 02, 2017 | Amana AGR5715QDS Gas Kitchen Range
Gas Fireplace pilot light continually goes out
You may have a problem with the flame sensing capillary. It may need to be replaced, or it may need to be positioned into the pilot flame better, or you may need a new gas safety valve. Sometime there is an adjustment screw for the pilot which can make the flame bigger or smaller. If will be on the safety valve.
Oct 14, 2008 | Grilling
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
