Question about LG MV-1444Y Microwave Oven
Galaxy microwave I put something in micro for 2:30. After 15 seconds heard loud pop and smell of burning plastic. I opened front cover but can't see any burn marks. I think it could be the capacitor but I'm not sure. Any help?
  • LG Master
  • 9,086 Answers
When the high voltage capacitor fails, it almost always shorts, always resulting in a blown fuse.
Your problem is most likely a shorted / blown high voltage rectifier diode.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
To order parts, the best i can suggest is to call the number in your owner's manual or have a local appliance parts store match them up.
Posted on Sep 27, 2008
Run microwave empty
I would never recommend using a microwave that emits a burning smell.
Mar 27, 2014 | Samsung Microwave Ovens
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
Heard a pop and then an electrical smell. Unit is working but a faint electrical smell occurs each time unit used. Should I continue using it? It is built in with a trim kit.
No that is a very dangerous situation. What is sounds like is you had a short that blew apart but not completely damaging the wires. You should unplug, and open it if its out of warranty and inspect the wires. If the wires are partially burned it can heat up and cause an electrical fire.
May 19, 2010 | Panasonic NN-S541 Microwave Oven
Burning smell and won't heat.
If it buzzes real loud it's probably the high volyage diode. However some times if it smells it's the transformer. Usually the diode is a cheap fix ~$10.00 but this model the diode is $50. It's number 50 on the link below. Let me know how it works out or you need anything else.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JVM1440BH01&productCategoryId=0123370&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=G0312014&pop=flush
Apr 19, 2009 | GE JVM1440 Microwave Oven
Is the microwave possibly dangerous after it popped & now smells
Hello jeffnlaur,
The sound you heard could be any number of things but I would attempt to verify the basic preformance of the microwave was ok by placing a cup of water in the cooking compartment and switching the micro on for about 2 minutes.. The water should be close to or at a boil after this time ( depending on glass type and power output of oven). Listen for any other irregular sounds while it is running. You may have heard something in the soup pop or some of the electronics within the micro arc but it may not mean it is dangerous. Try the water test first and if it continues to exibit internal noises and burning a burning smell, I would discrad the oven. Table top models are very inexpensive and the cost to diagnose and repair would probably exceed the cost to replace,
In terms of dangerous, there are safety devices to cut off power to the magnetron and other components if warranted. Not sure that helps you but with limited info from your side, diagnostics are 'iffy' at best..
Regards
Rick
Jan 09, 2009 | Panasonic Microwave Ovens
Loud grinding sound and mechanical odor
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please reply back with more details if this does not solve your problem.
Aug 10, 2008 | Kenmore 62622 Microwave Oven
Loud pop with smoke
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from AppliancePartsPros.com/Parts
May 23, 2008 | Emerson MW8107WA Microwave Oven
Microwave turns, gives out strong burnt plastic smell, little (or no) heating
I would first suggest that you look inside the cooking cavity to see if your wavegudie cover is burned or carbonized. If so, it will need to be replaced. You can order one via Tritronics at http://www.wehaveparts.com The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Once you remove and / or clean the cover and clean the opening of the waveguide, if it still won't heat and/or still has the smell, you may have a bad magnetron or high-voltage transformer. Feel free to post back if you still have trouble.
Dec 05, 2006 | Sharp R-1610 Microwave Oven
LG MV-1444Y Microwave Oven Logo
274 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
