I have hooked up everything as directed but it says there is no connection to the internet
What kind of internet connection do u have? IF high speed, power cycle the system. unplug the modem and shut down the computer. wait 5 minutes then plug the modem back in. once all the lights r steady the turn on the computer.
Posted on Sep 24, 2008
I have a Toshiba Satelite A205-5000. I have bought 2 new routers, one Linksys and Netgear. It gets a network connection but the IE exploer will not bring up sites. It acts like it does not get a good...
Hi there, Before we start, try hooking your laptop up directly to the modem - if you're not getting an internet connection there, call your Internet Service Provider. If you are, then follow the steps below.
1) Make sure that you're not using more than one router at the same time. One router should be hooked up directly to your modem in the WAN port. If you have wireless security enabled, go to step 2 2) As a test, remove the security on your wireless network and then see if you can access the internet properly. The router can be accessed by typing it its address in internet explorer, as long as you are connected to the router. Generally the address is 3) If you still can't access the internet, go to Internet Explorer Options, the Connections tab, LAN settings, and make sure "use a proxy server" is NOT checked. 4) If you DO get an internet connection now, go back to your router and enable WPA security (some older laptops have problems with WPA2 connections).
If everything doesn't work, post back with some more details! Alex
May 30, 2011 | Toshiba Computers & Internet
I wish to use internet for my wii yet my alltel wireless huawei cannot connect directly. ive tried using a lan adapter hooked into the wii and an ethernet cable hooked from that to a router, then using...
Turn on the wii, go to settings, go over until you see stuff about internet... select it and from there add your network, type in your password, put your encryption type, and security like WPA or WEP...... You just have to make that your connection and click test connection if everything goes through select use network and enjoy internet on your wii = )
Jan 11, 2011 | Video Game Consoles & Games
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
What is and how do I get an IP address to hook up a router?
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I checked my firewall. All cords are connected properly. The same
When using a router with your internet connection (cable, dsl modem etc.) hooked directly to the routers data port it will use the roughter's dhcp to assign ip addresses to other computer on the network. If you have your internet connection hooked directly to a computer and are using internet connect sharing then you must disable the dhcp service on the roughter because the internet connect sharing has its own dhcp and it will assign all the ip addresses. to get into the roughter's setup you open a browser (internet explorer, mozilla etc.) and type
Aug 22, 2009 | Linksys Wireless-G Broadband Router
I have a dir 300 router that when i try to hook it up it i cant
 Let me clarify this  your internet works when your PC is hooked up directly to the modem....
When you connect the router between the pc and the modem the internet does not work....
This sounds like the configuration settings inside the router need to be setup or adjusted.
Go to the web browser and type in and for the username type admin and then leave the password blank hit enter and it should sign you into the router. Follow the setup wizard and everything should work just fine.
Hope it Helps!
Apr 12, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Aug 09, 2008 | Belkin Computers & Internet
Cannot complete downloads
when you say that everything works when the router is NOT hooked up to the PC, does that mean that you have the DSL modem connected directly to the computer?
then, when you hook up the router, you're connecting it BETWEEN the DSL modem and your computer?
You probably need to log in to your router and set it up to connect through the DSL modem to the internet: it may not do it automatically.
is this computer running windows XP?
if so, go to control panel, then network connections.
if you double click on the local area connection, and go to the support tab, it should list something like this:
Address type: assigned by DHCP
IP address:
Default gateway:
Try opening internet explorer, and typing in the numbers it lists for default gateway.  hopefully, that will bring up the configuration screen for your router.
Mar 26, 2008 | Computers & Internet
Stopped connecting to the internet
What kind of connection do you have? (Cable, DSL, etc.) Post an ipconfig /all result (Run, cmd, ipconfig /all) Delete your current connection and re-create it.
Sep 01, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
