Question about HP DeskJet 3745 Printer
Printing My HP #3745 printer light started blinking nonstop. I did the test of removing one cartridge at a time and it seems both cartridges need replacing. I replaced a new black cartridge but do not have a colour one at present. Is there a way to print with only one cartridge?
  • mwisho Oct 21, 2008
    sum one jammed the printer with paper and removed the paper from the front instead of opening the back cover. now the light keeps blinking on and off. i have switched off the printer and restated the computer but the problem persists. HELP
Jjj
Posted on Sep 24, 2008
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Tip
The green light is blinking constantly and the printer won't print
Often happens HP cartridges to overheat.In that case the printer not recognize it and the green lamp blinking constantly.In most case only one of both cartridges defective and need to be replaced.But how to know which one?
Here's how: Open cover, put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
on Oct 21, 2009 | HP DeskJet 3745 Printer
I have an HP DeskJet 3745 Printer installed in Windows 7 32-bit. It's properly installed, and it actually works -- the power light is on, and the containers of the cartridges move when printing. Only that,...
uninstall the printer, and go to HP.com, download the install program for your printer and OS, and follow install directions exactly, do not plug and play.
Sep 28, 2010 | HP DeskJet 3745 Printer
Hp printer 3745 is printing in green only.
Uninstall your printer software and install it again and try to print again. It should work.. because your printer setting seems to be messed up. If it still does not work then it is recommended that you change your ink cartridge
Have a nice day!
Jan 19, 2010 | HP Deskjet 3745 Inkjet Color Printer
Color printing in hp 3745
i need driver deskjet 3744
Sep 29, 2008 | HP DeskJet 3745 Printer
Hp dj3745
it means either there are pending documents in the print que delete them,if no pending documents remaining in the printque.
then either of the print cartridge is faulty.remove the cartridges 1 by 1 and check and see whether its blinking .
if the blinking stops after removing black cartridge the blck is faulty, or if,the blinking stops after removing the colur cartridge the colour is faulty.
if still blinking then both the cartridges are faulty.
thanks.
Sep 16, 2008 | HP DeskJet 3745 Printer
Printer bling ect
Dear friend this light blinging problem is with Print cartridge please check cartridge with Ok printer .
100% u r problem is solved ...
& at ones time Printer get all paper
this is a default printer tray alliment problem .so u take care that your paper bunch is no longer insetred in to printer just under pickup roller.
if problem is solved please Rate me ...
May 23, 2008 | HP DeskJet 3745 Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Won't work, "Colour" indicator + "Check cartridge" indicators blinking all the time when the printer is on, although the colour cartridge is only half-full. And when I say "won't work", I mean it - won't...
I had the same problem and I accidentally found out that if you press the cancel/resume button + the color scan, the printer starts printing a test page I had never seen before (includes error codes and stuff?!?!) and color as well as black comes out perfect but it will go back again into color cartridge problems after printing. Could it be something with the printer software itself? Hell, I am kind of getting sick with HP products. They are overrated and cannot be serviced. Kinda disposable printer although it was being sold as medium range all in one printer.
Jan 14, 2008 | HP PSC 1510 All-In-One InkJet Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
HP DeskJet 3745 Printer Logo
162 people viewed this question
Ben Johnson
