Question about Gaggia MDF Electric Burr Grinder
Gaggia mdf coffee grinder
Hi
I have broken the "basket" (half circle)?? or whatever you call this part and was wondering if I can replace it. Otherwise it works WELL
Monique Thank you
Contact this number (see below) they will also tell /send a diagram on how to fix it...
Whole Latte Love
Customer Service
Phone: (888) 411-5282
Fax: (585) 924-7362
customerservice@wholelattelove.com
Posted on Apr 12, 2009
    Novelist:
  • 137 Answers
Try to get that part at:
www.nuovaricambi.it
Posted on Apr 04, 2009
I just disassembled and cleaned my Gaggia coffee grinder. When I turned it on to calibrate the burr plates it made a short grinding sound then stopped and now won't turn on
Take it apart again and check all the connections and switches, security shut-offs, and THE THERMAL SWITCH. A very small and cheap electronic device that takes and overload and will shut your system down, whatever it is. Very easy and quick to replace.
Nov 25, 2014 | Gaggia MDF Electric Burr Grinder
How to replace fuse?
follow where the power cable tracks are and you will find it near the positive wire track.
Sep 21, 2017 | Gaggia MDF Coffee Grinder
Need operating & maintenance manual for brevetti gaggia mdf burr grinder.
Hello, your instruction manual can be found on this link by clicking or copy and pasteing it to your browser http://www.gaggia.com/dam/bo/allegati/files/31_mdf.pdf if you are unable to obtain these instructions by copy and pasteing to your browser please message me back and I will provide my email so that I may send you them directly.
Thank you
Rick
Nov 08, 2011 | Gaggia MDF Electric Burr Grinder
I have a Gaggia burr grinder, Brevetti Gaggia SA Model MDF, s/n 7262. The handle that you flick back and forth to let the grinds come out broke off inside the unit.fixable? 707=837-8916 Thanks Anne
Look inside the grinder, The lever is attach to a SPRING .
May be the lever is disconnected (unhooked) from the spring.
AND YES IS FIXABLE.
It cost you about $15-$30 for the parts.
Jan 15, 2011 | Gaggia MDF Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
Unit over heated
You will have to dismantle the burr chamber and clean out all the grounds, make sure the hole to the dosing chamber is clean also. Check the rectifier and filter assembly behind the motor to make sure nothing is burnt. Reassemble and test grinder.
May 03, 2009 | Gaggia MDF Medium Duty Coffee Grinder Wtih...
Re setting
There is no way to do this. One controls flow by the pressure of the tamp, and fineness of the grind. 2.25 ounces or espresso in 20 seconds from 14 grams of coffee.
Dec 02, 2007 | Gaggia Coffee In White, White MDF...
How long should it take gaggia mdf to grind?
I'm not familiar with this exact model but the problem may be either packing in the unit...since it never worked...or that the beans have jammed the unit in such a way that none are feeding to the burr. Usually, there is a way to remove the top half of the burr after removing the beans. Brush out the area and reinstall. The instructions that came with the unit should be of value. By the way, on some of these units, if the cup isn't correctly placed, it may prevent the burr from receiving flow. Enjoy!
Nov 29, 2007 | Gaggia MDF Electric Burr Grinder
Broken Handle on Coffee Grinder
Nice unit! Replace the part. Try www.smallappliance.com.
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Nov 24, 2007 | Gaggia MDF Coffee Grinder
Gaggia MDF Electric Burr Grinder Logo
262 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
