Question about HP Office Equipment & Supplies
A new color cartridge 97 was producing blurred or bad color photos from the very start. I returned it and brought anothernew one home, inserted it andthe same thing is happening. What is wrong with my printer ? L.James Alexander II lja29@comcast.net
    Guru:
  • 558 Answers
May be your printer is set for Fastdraft.
Check the printer setting by
Start--> Printer and faxes -- > printer Window open
Now select the properties.
Now here you can see the Page setup and color setting.
Please change it and then try.
Let me know if you need further assistance.
Regards
Ellin
Posted on Sep 24, 2008
  • HP Master
  • 6,487 Answers
CAn you please inform us the model of this printer so we can help you better...
Will not print. says code 2200 just replaced black carterage
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3. 3
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved. 4
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge. If the printer fails again, continue toContacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. the 2200 error is a scanner error means the scanner motor failed to initialize. lexmark recommends that you unplug the unit remove the power supply wait a couple of minute reinstall the p/s and power the unit back up. step to is repeat step one but us the belt to move the scanner carriage to the middle and power it up.
on top of this i would inspect the guide bars for dirt build up and clean them if need be. one thing to consider the ccd knows that it has reached home by the reflecting of the light to the carriage home photo cell within the scanner itself. this light is reeflected back off of the mirrors inside of the ccd. dust on these mirrirs will prevent the photo cell from nowing where home is. these can be cleaned with q-tips
plz rate the solution
Nov 02, 2010 | Lexmark X7170 All-In-One InkJet Printer
Blurred printing new black cartridge installed - we still have blurred printing.
It is problem on cartridge setting may be it select color cartridge.or clean your black cartridge check nozzle print test.
Feb 12, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My Lexmark X71700 shows a 2200 error
Yes: Repeat step 4 with another black / photo cartridge. If the printer fails again, continue to Contacting Lexmark.
Nov 07, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
The color ink cartridge '97' is being rejected by
hi,
this problem may be due to the senser in socket where you are insert the cartridge. so pls clean the socket with cotton using cleanin g liquid eg petrol , spirit or even nail polish remover
Aug 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
Colors print blurred
I had that problem too. The weird thing was if I printed in black and white, the printing was fine. For me it looks like it was a new defective photoconductor unit. When I stuck the old one back in, no problem but my old one was producing 4 color dots all the way down the middle of the page. I went on eBay and brought a re-manufactured one (buy at your own risk) and the color printing was perfect again.
May 29, 2009 | Epson ACULASER CX11NF All-In-One Printer
Color
Sometimes even a new Cartridge is bad depending on how long it was sitting on the Shelf. I would try a new cartridge. i f that works, return the bad one.
Feb 12, 2008 | Office Equipment & Supplies
Error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
22 people viewed this question
Seeker5211
Seeker5211
