Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50v715 model
How difficult is replacing tv lamp?
    Problem Solver:
  • 12 Answers
Step1 Turn off the TV, and unplug it. Make sure to disconnect it from the outlet completely. Step2 Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb. Step3 Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver. Step4 Gently remove the bulb. Pull the bulb out of the compartment, usually by grasping a handle and then pulling out and slightly down. Step5 Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the television. Slide the new one into place. Step6 Tighten the screws. Do not overtighten them; they should be finger-tight only. Step7 Close the door. Make sure it is closed completely or the TV will not operate.
it depends on if your a handyman
Posted on Sep 24, 2008
I have a 50V715 purchased in 2004 no picture.
U used this tv alots?About 4 or 5 hours a day?It time to change the projection bulb,the live span of the bulb are over.
Apr 28, 2010 | Hitachi 50V715 50" Rear Projection...
Picture is very dark and hard to see
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is UX21513.You can find it here: http://www.discount-merchant.com/Hitachi-UX21513-LM500-Replacement-UHP-Lamp-Proj-p/hitach-ux21513-lm500-lamp-bulb.htm?Click=48173 Have a blessed one!
Apr 04, 2010 | Hitachi 50V715 50" Rear Projection...
When i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
Hi, Does the set come on for about 30 sec.? I had a 50V715 hitachi, it came on for about 30 sec. then shut down and then it would repeat the process. After about 3 wks and alot of other pain, it turned out to be the lamp was weak. Replaced the lamp and all is great! So... it could be your lamp is going bad. Hope this is helpful.
Nov 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Tv power light keeps blinking wont stop tv does not come on.
Hi I don't know what model you have, but the 50v715 I have, did the same thing and it turned out to be the lamp. If the lamp has not been changed in a couple of years, its probably time to get a new one. I hope this is helpful.
Nov 10, 2009 | Hitachi Televison & Video
50v715 hitachi..the tv was on doing fine then it went off and the 2 red lights blink. What can i do to fix it?
If is the lamp and temp light on the front panel, then it could be that the bulb (lamp) needs to be replaced. Make sure you buy an original replacement lamp (phillips) they are supposed to last longer. There are also videos on you-tube that show you how to replace the lamp. Hopw this is helpful.
Nov 07, 2009 | Hitachi 50V715 50" Rear Projection...
Hitachi 50V715 power on/off problem
I would check to see if any of the fans stop turning or don't turn when set turns on. They do have sensors monitoring them and the set will shut down if they are not turning. I believe there are three fans around the chassis.
Hope this helps,
Skyassoc
Oct 23, 2009 | Hitachi 50V715 50" Rear Projection...
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
Oct 18, 2009 | Hitachi 50V715 50" Rear Projection...
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
My power shuts off on my tv
I don't know what model you have but, mine is a 50v715 and it did the same thing. It turned out it was the lamp. So you might just try changing the lamp. Hope this is helpful.
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
