Front load washer drum has dropped down - Washing Machines
  • 172 Answers
Hi cgtires,
I hate to be the bearer of bad news but if the tub is dropped, your support brackets on the tub may be broken. This repair is a major repair. You would need a new tub, and the labor takes several hours. I am affraid it may be time for a new washer. Feel free to call us if you need to ask questions. My name is Mike and I am the owner of a Appliance store.
(865)945-3808 Advise is always free
Posted on Sep 24, 2008
SOURCE: front load washer loud noise and drum loose but not dropped
How is this done
Posted on May 30, 2009
venexcsd
  • 1185 Answers
SOURCE: my frigdaire front load washer ate my underwire bra wire
Do not attempt to remove a drum unless you have been trained to do so
First thing to do is to dump the back drain hose into a big dish and drain off all of the standing water
in the machines sump.
Remove the power !!
Tip the machine towards the back and front to get as much water out of it as possible
Tip the machine back agains a wall or a bench with a cloth protecting both surfaces
Put a wooden block underneath the front edge of the machine in case it falls on you
Get a torch and look at the bottom of the drum , there will be a big hose connected to the base with a jubilee clip or spring clip
Remove the clip and pull the hose off , place a cloth on the floor as there may still be some water in the hose , if you are lucky the wire will be either in the hose or in the sump that the hose is fixed to.
If the hose is connected to the rear of the drum tip the machine as far back as possible allowing the wire to fall within reach of the hole
If you cant see it get a magnetic retriever or a piece of bent coat hanger and go fishing.
If the hose is fitted to the front of the drum reverse the machine and lay it on its front or as far forward as possible , that way the wire will fall towards the hole
Posted on Jun 03, 2009
  • 4090 Answers
SOURCE: Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Posted on Aug 18, 2009
SOURCE: frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Posted on Dec 06, 2009
  • 2468 Answers
SOURCE: my washer was spinning, it made a loud noise and
you left it go toooo long and the drum bearings in the rear area have finally given way,the "lip-seal" that keeps water out failed some time ago and now the bearing(s) also went,this may be quite a costly affair getting the old bearings out of the plastic outer drum bore,if its even savable,bearings and seal are cheap,appx $70.00 for these/the drum if damaged $500.00+/the drum spline and spider that holds the drum $150.00 /plus labor depending how bad
Posted on May 10, 2010
Why has drum fallen out of place?
You have a bearing problem and best if you call a service company on this one!
Aug 09, 2015 | Samsung WF448AAP Front Load Washer
Ghw9150pw0
Drum bearings gone..or Suspension unit that supports the full drum inner and outer.
Oct 28, 2013 | Whirlpool Duet 3.8 cu. ft. Front Load...
When spinning at higher speeds, there was a sound that could only be the drum hitting or catching something. The drum has now dropped about an inch. I took it all apart yesterday & could see nothing...
It's hard to give much detail without a model number, but it sounds like you are working on a front load washer.
If the tub of a front load washer has dropped down and is rubbing on the outer tube as it spins around then I would suspect the rear drum bearings are bad.
You can remove the back access panel from your washer and see if there is a trail of grease and water residue running down from the center tub bearing.
Aug 03, 2011 | Washing Machines
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
Door locked with clothes and water trapped in side. Drum moving slowly and "clunking"
If you remove the drain hose from sink, drop it down low into a bucket,this will gravity drain and allow you to open the door to remove clothes, clunking could be object stuck in the drum or the pump even,at worst Drum bearing failure..Good luck
Apr 01, 2011 | Zanussi ZWF1430W Front Load Washer
My washer was spinning, it made a loud noise and the drum dropped down in front
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Jan 28, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
We went to tumble dry towels but when going back to the machine the drum was full of water and the towels soaking wet! Now we can't get rid of the water in the drum. We even tried to run a program to drain...
If you can, lay the drain outlet hose down to floor level, and let the water run into a bucket or similar.
Then check the filter, which should be located at the bottom front right of washer behind drop down flap.
Remove and clean by unscrewing it anti-clockwise.
Hope this helps.
Jan 20, 2010 | Zanussi WJD1257W Front Load Washer
Water remaining in the drum after cycle
Sounds like the filter needs to be cleaned
This is located at the bottom front right of washer behind drop down cover or flap.
Jan 15, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Jan 02, 2009 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
