Power cord came out the back of the tv - Televison & Video
    Sergeant:
  • 300 Answers
1. Replace the power chord.
WARNING HIGH VOLTAGE: Do not attempt to work on your set without another person present who is trained in CPR
If the power chord is a plug in type , plug it back in.
if the power chord was ripped out , you need to repair it.
if the power chord was broken before you discovered it, you will also need to repair it.
I do mean a proper repair not just an electrical tape job.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division.
Posted on Sep 24, 2008
HI NEED HELP? TV WONT TURN ON?
Unplug the power cord from your TV. Wait 30 seconds, then plug it back in. Plug the power cord into a different power outlet or power strip. If possible, try a different TV power cord.
Apr 13, 2017 | Televison & Video
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
The volume in my tv dont work
Try setting back to factory default
Power off tv
Unplug power cord to wall
wait approx 10 minutes
Plug cord back in
power on tv main menu will appear follow on on-screen instructions to reprogram.
Apr 13, 2013 | Panasonic Tc-p50c2 50-inch 720p Plasma...
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
I relocated to another state and I have a Sansui HDLCD1908 tv, I have this extra power cord I'm assuming it connects to the tv, all the other cords to all the other electronics are accounted for and...
It will connect in the back of the TV. You will see a female socket under the lip of the RCA connections and RF connectors. This power cord is just like the computer power cord you already use! Thanks for asking and show a few hands of support!
Mar 04, 2011 | Sansui HDLCD1908 19 in. LCD TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Power cord pulled out
i have just pulled the back by removing 5 or 6 screws. you can see the circuit board, and the power cord is soldered directly into the board. two wires,one black and one white. near the left back corner--- from the back. you can re solder it.
Mar 27, 2007 | Sanyo DS25390 TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
