Our Ariston Margherita 2000 AB95 Sounds like a jet plane when spinning Is it worth fixing?
  • 750 Answers
Hello chels_z
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your Ariston Margherita 2000 AB95 Sounds like a jet plane when spinning
And asked me Is it worth fixing?
That depends how old the unit is?
Let me know what the results are.
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 24, 2008
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Jan 20, 2010 | Ariston Technologies Washing Machines
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
1,722 people viewed this question
Top Washing Machines Experts
