Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Self Propelled does not work
U6439900 will not self propel, pushing or pulling action handle does nothing, how do I fix it
  • SC1959 Apr 08, 2009
    I can see the arm/lever snapped right where the cable attaches. This seems to me to be a design flaw as my vacuum has not been abused and is not terribly old.
  • 37 Answers
If you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Posted on Sep 24, 2008
My Hoover model U6437-900 (wind tunnel) the Self-propel no longer works. I have checked/replaced both belts. I was wondering if there is a cable going from the ,Self-propel button (on the handle) down to the wheel drive. If so, is this a job which I can handle.
Posted on Aug 14, 2011
Can't lower handle on Hoover u6432-900 so can't clean floo
usually theres a plastic pedal you would step on to release the handle.... first thing i would try is pushing up (foreward) on the handle and try pressing the pedal .if the pedal wont push down at all then something might have gotten jammed down in it..... at which point you'd have to do a bit of fiddling around with it to see whats keeping it jammed up.....also... there could be something stuck in there thats keeping the handle from being able to move down.... as for the self propelled part.... it probably wont work untilthe handle is lowered... hope this helps
Nov 12, 2013 | Vacuums
Self propelled clicking noise
check the cable that connects from the handle to the power drive. you might have broken a fastener between the two.
Dec 26, 2012 | Vacuums
How to remover the hood from hoover u6439900 vacuum, all screws have been removed but something still holding it on.
Your vac is a Self Propelled Hoover Windtunnel upright. It should have two small buttons on the top of the hood that control the self-propelled feature and the height of the carpet being swept. These two buttons must be removed in order to completely remove the top of the units head, even though you may have all the screws loose and out. They generally don't come easily, so unless this is a real serious problem you're dealing with you might want to consider just closing it back up
Jul 14, 2011 | Vacuums
The vacuum is not rolling easily. It "drags" on the rug.
Hi There,
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self-propelled Broken?
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Aug 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Help
dyson vacuums are not self propelled. and if you cannot push it on your carpet then the pile of your carpe is more than what the vacuum can handle.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
722 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
