Question about Alpine CDA-9851 CD Player
Alpine CDA-9851 CD Player : Time Display
I can set the time on the player, but how do I get the unit to display the time when the player is turned off but the vehicle is running? (Kinda like the factory models do?)
I turned the clock ON while the radio was on, then when I turned the radio OFF, the clock continued to display. Nice.
Posted on Sep 25, 2008
1st time using and really I'm kinda lost.
Well if the unit is charged, connect negative to negative and positive to positive and set the unit to "On".
Nov 25, 2013 | JUMP START SYSTEM
My Jensen VW9424 Navi unit doesn't keep the correct time. The unit displayed a time 30 minutes ahead of the correct time after installation. Several attempts have been made to set the correct time;...
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
May 25, 2011 | Jensen VM9424 Car Video Player
HOW DO YOU SET THE CLOCK ON THE DEP-P4000UB
STEP ONE (PRELIMINARY): With the key in the ignition, turn the ignition to ACC (accessory power) or this can be done while the vehicle is running. If unit remains off, proceed to the next step, but if unit is already powered on, power it down by pressing [Source] until it goes off. (Then, proceed to the next step.)
STEP TWO: Press MULT-CONTROL & hold until CLOCK SET displays. (To cancel at any time, press [Band/ESC]. Press [Back] to return to previous display.)
STEP THREE: Press MULTI-CONTROL to select the desired segment of the clock display to set. Each time MULTI-CONTROL is pressed, it selects (blinks) one clock display segment: Hour - Minute.
STEP FOUR: Turn (or push) MULTI-CONTROL (up/down) to change the clock display segment setting.
Apr 10, 2011 | Pioneer Car Audio & Video
I have an Alpine CDA 9851 and the cd player shows that it's playing...by that I mean the timer for the player is running, but there isn't anything coming through the speakers...is the player bad or does...
Hello .... your Player show the counter is counting but you don't have any sound .. Check your Main connection between your Radio and your CD deck player it possible your sound terminal connection is unplug due to excessive vibration on a bad driving road
Oct 15, 2010 | Alpine CDA-9851 CD Player
How you tune stations and set clock
Setting the time This is used to set the time on the unit?s clock display. 1 Press SOURCE and hold until the unit turns off. 2 Press AUDIO and hold until TIME (12:00) appears in the display. 3 Select the portion of the time display you wish to set with 2/3. Pressing 2/3 will select a portion of the clock display: HOUR?MINUTE As you select portions of the clock display the portion selected will blink. 4 Select the correct time with 5/∞. Pressing 5 will increase the selected hour or minute. Pressing ∞ will decrease the selected hour or minute. ? To cancel time settings, press BAND. ? You can also cancel time settings by holding down AUDIO until the unit turns off. You can download users guide here http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man good luck
Mar 09, 2010 | Pioneer DEH-14 CD Player
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
My LG combo player recorder will not read netflix dvd's
I had the same problem.
1. check that the disk region is the same as you unit ( it is the global of the world on the CD has a number in the middle, now check the back of your player. They must be same region.
2. Turn the unit on
3.Press the power button and hold for 10 Seconds
3. Turn the unit back on, wait for the time to display.
4. unplug the unit and leave unpluged for 30 seconds
5. plug the unit back in and turn it on, the time should not display should be blank.
6. Unit should go into startup wizard like it is being started for the the very first time. follow the prompts.
7. In the setup menue, I believe it is under disc settings, select set to factory settings.
Once I completed these, I put the netflix movie back in and it now runs,
Hope the same works for you
Jul 20, 2009 | LG RC797T
Alpine CDA-9851 CD Player Logo
184 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
