Question about Refrigerators
Amana refrigerator top freezer going out; water under crispers
I have a '93 Amana with top freezer. Only the bottom of the freezer will freeze anything. The other two shelves are progressively warmer and neither will freeze. The other problem is that water is building up inside of the refrigerator, under the crispers. I have notice that the drain hose appears inoperable, and the water pan is as dry as a desert. I put a wire up the hose, which stopped at about the point where the freezer starts.
My theory is that the hose has become plugged, water has built up and froze someplace in there, and because of that blockage the water has no where to go so its running down the inside and that's why the crispers are wet. This is just a theory.
    President:
  • 1,462 Answers
You are right about the cause of water in the fridge - blockage in the drain. i'v never met this caused by ice but it is possible.
with the freezer, the cause of the fault is the fan not working - probably jammed with ice. take back panel off inside freezer and check for ice build up. if loads of ice thgen defrost system has failed. you can do a temporary repair by melting the ice off with a hairdryer
Posted on Sep 24, 2008
Water leaking
If there is water under your crisper drawers your drain line under your freezer panel is clogged up or frozen over.
Jul 28, 2012 | Amana ARB2257CSL Bottom Freezer...
Amana BB20VE - Food Freezing in Crisper
Have you checked it's not in fast freeze mode, and that the setting on the thermostat is about in the middle?
Apr 18, 2012 | Amana Refrigerators
Veggies in crisper drawer are freezing,what is causing this?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Amana AFI2538A Bottom Freezer French Door...
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water under the bottom of the frezzer
I would thaw all ice out use hot water in the drain hole. also use a heat probe in the drain hole. Is the drain tube straight or does it have a trap in it.
Mar 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water in the bottom of the refrigerator
you have to take out the back postion in side the freezer please ulplug the refrigerator under the evaparator is the drain throw hot water in there
Mar 30, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from top of fridge then freezing under crisper's
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hi jimorso,
Your theory is correct. You will have to defrost the drain and clear any other obstructions to get the water draining correctly again. To do this you will have to go in through the freezer. Remove the back panel by removeing the 3-4 screws that hold the back wall in place. You will see the drain directly under the coil. It will be a small hole and it will most likely be covered with ice. YOu will need to defrost all the ice and clear the drain. If the coils are frosted up you may have other issues like a defrost heater that is bad. The defrost heater is directly under the coils and you can simply check for continuity through the heater.
The drain is sometimes difficult to defrost, I use a towel to dry water, and I use cups of hot water to pour onto the ice, then just dry up the mess as you make it. You can also rub the drain with your finger to help defrost. I also use a flexable ruber hose to blow air into the drain untill the drain is clear again. If you have any other questions please just ask. I hope this will FixYa. Please dont forget to rate me.
Mike
Sep 24, 2008 | Amana ATB1935HR Top Freezer Refrigerator
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
