Casio wk 3000 keyboard will not turn on.
The power chord is fine. I have checked that. When I try to turn it on, it won't come on.
  • johnny949 Dec 22, 2008
    I have exactly the same problem. The DC socket seems too big for the plug which is loose when inserted. Do you have a solution yet?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi ernieclay
    If you have found that the external power supply is working ok, then I would expect that one of the following has stopped your keys from working.
    1. the DC socket has cracked printed circuit board lands,
    2. the soldering to the DC socket has failed
    3. the DC socket itself has failed.
    There are only a couple of types of purpose fit DC sockets for Casio Keys, and they are generally readily available from Casio direct, or a good keyboard repairer in your area(I used to keep them in stock)
    If you let me know what country you live in I can direct you to a source of a new DC socket is you require one. A FixYa is a great reward for my efforts to assist you. If you need more help, happy to oblige:)
2 Suggested Answers
  • 96 Answers
SOURCE: RE: Casio wk 3000 musical Keyboard only reads Ples Wait
I am not shure but it sound like a hard drive problem, does it have a hard dribe that keep's it's memmory.
Posted on Feb 08, 2008
Stuck in sleep mode
remove the battery and unplug your power chord for 1 min. then plug your power chord back in and try to turn it back on.
if it works then plug your battery back in and see if it boots your system up without the power chord.
if everything works fine then go into your control panel and change your power options.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
I have a sharp lcd 32 inch it stopped working, it won't turn on.
Try to check the main line and if its ok proceed to the power chord then to transformer or the fuse and you look it they are fine look for a technician to check your tv.Choose a better technician near from your place.
Nov 06, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
Hp c5280 wont switch on, its been working well when last used this morning.
Disconnect the power chord from the back of the printer. Wait for 40 seconds and connect it back and check if it is warming up or not. If not the press power key for few seconds and see if it turns on or not.
If not then check if the adapter is getting warm or not after it is connected to wall outlet.
If adapter is warming up then try another power chord and check..
If both power supply are getting warmer then problem is with printer hardware and if printer works with another power chord then replace the damaged power chord
Feb 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
Power cord not working
Try unpluggin the power cord and check with battery.
Check whether battery is charging with the power chord on.
Try with a different wall socket.
If this does not help.
Try with a different power chord of the same kind and check whether it works.
If yes, the power chord is the ussue. Best would be to replace it.
Try your power chord in a laptop similar kind and check whether the other laptop works fine.
Try juggling the power cord and check whether it gives supply.If yes then check for AC adapter for any damages or cuts. If any is found the contact manufacturer for replacement.
else Main board is the issue.
But before this I would request you to go to the website and check for Updated BIOS and updates for chipset driver.
If any is available then download and install.
Check with your AC adapter if it works, Good, else I would request you to contact the manufacturer for a Main board issue.
They would replace the main board if under warranty.
Jul 22, 2009 | IBM ThinkPad T43 Notebook
No power (breaker, power chords, outlet are all ok)
If you have power to it and it will not turn on at all your switch needs to be replaced. You could try cleaning it first and giving it a squirt of electronic contact spray.
Hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out:
Jul 11, 2008 | HP Media Center m7060n PC Desktop
Printer problem
have you tries inserting new set of ink cartridge???
try this...
> unplug the power chord.
> remove the rear access door.
> check for any jammed paper. if so remove it.
> clean the rollers using a lint free cloth.
> close the rear access door.
> keep pressing the on button for 20 seconds
> try to copy
if no go
> unplug the power chord while it is turned on
> remove the cartridges
> press and hold the ok and cancel button at the same time.
> while holding them insert the power chord, and wait for few seconds and then release your hands.
> when it asks for the ink cartridge, insert them ad check.
if no go, contact me
thanks and regards
Mar 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
try this
> connect the power chord directly to the wall socket.
> check with different wall sockets.
> unplug and plug in back the power chord. make sure that it is securely plugged in.
> check whether there is a light on the box which comes between the printer and the wall socket.
> if there is light and you hav the problem u need to service the unit else power chord may be the problem.
thanks and regards
Feb 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Pulled the chord while the lamp was on. HP vp6310 does not light upanymore
One of the transistor on the power supply is blown. I can repace it.
Dec 07, 2007 | HP VP6310 Multimedia Projector
No Power
i'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Aug 16, 2007 | Toshiba 20HL85 20 in. LCD Television
403 people viewed this question
