Question about Refrigerators
I have an Amana fridge with an internal ice maker. It suddenly stopped making ice. The lever that moves up and down popped out and I put it back in but now there's no ice. Can you help?
  • 943 Answers
Hi thanks for the question is the arm in the down position and is the arm put back in its proper position check that thanks please leave a positive feed back the appliance doc
Posted on Sep 24, 2008
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I get the ice maker to start making Ice?
WATER + ELECTRICITY = ICE. ABOVE THE ICE TRAY IS A THICK WIRE LEVER MAKE SURE IT IS DOWN.... WHEN THE ICE LEVEL GETS HIGH, ICE PUSHES THIS LEVER UP AND STOPS THE ICE MAKING CYCLE.
Sep 06, 2014 | Amana Refrigerators
How do I turn off the ice maker in my Amana refridgerator?
There should be a stiff wire arm above the box where the ice cubes are stored. Gently lift the arm up until you feel a little jump. Let go of the and it shoould stay there. That turns off the ice maker. If the wire arm drops back down, lift it a little higher until it stays up. If you are going to move the fridge, make sure the water hose in back of the fridge is turned off and disconected or you will have a mess to clean up. When you want to turn it back on just lower the wire arm,
Nov 17, 2012 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
ICE MAKER IS NOT WORKING JUST STOPPED / TRIED MOVING TH E LEVER UP AND DOWN BUT NO LUCK
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
daffad
Jan 31, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Ice maker doesnt stop making ice
Check with an identical unit to see how that one moves. Yours may be dislocated. The lever arm probably contacts small plastic parts in the timer that could be out of place. Ice makers aren't too tough to take out and check out in a more comfortable work location. Just put a towel to catch screws.
Apr 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer not making ice in Fridgidaire model PLH269ZDB2
There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
