Question about Sony KP-57WS500 57" Rear Projection Television
Blue screen My KP57Hw40 Sony projection T.V flashes blue then shuts off after it's been on for only a mintue or two. After it shuts off the red light flashes for awhile. How can I repair it myself?
    Novelist:
    Champion:
  • 203 Answers
Very common problem on your model. you have a bad blue tube. in order to repair it you will need to replace the blue tube and then aligned it to the others. you will need to know a little about what you are doing. if you are interested in doing this yourself i will need a serial number off the back of the set to get you the right part number for the tube. This tube is going to cost you somewhere between $200-$300. To get this tube in there and looking right is a little of a fine art, I can walk you through this though. Let me know what you want to do!
Tim nolan
Posted on Sep 24, 2008
Testimonial: "knew the problem very well"
How do fix my 5 inch sony the light flashes 8 times
Prior to this were you getting a bright red, green, or blue screen with trace lines?
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
Tv screen turns blue and shut off. The red LED light flashes 9 times there after that.
The blue CRT has shorted and will need to be replaced. You should be able to get a replacement blue CRT from www.tvrepairworld.com
Aug 28, 2011 | Sony KP-57HW40 57" Rear Projection...
Hi..have a sony kp57hw40 after about 30 seconds on, the screen turns all blue..what would this be..??
most likely the blue gun is shorting out, or the ic on the neck board is defective,
or u can try turninr down the screen control for the blue gun
the controls access via the front panel,pull speaker grill off screws on sides or at bottom of grill
remove plate togain access to block of 6 controls, 3 are focus and 3 are screen brightness
center up/dwn are green
left up/dwn are red
right are blue
Apr 01, 2011 | Sony KP-57HW40 57" Rear Projection...
I have a kp57hw40 sony tv and the scren it flashs
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Sony KP-57HW40 57" Rear Projection...
Power on then off
Check the settings on the screen. If they are set too high set will cut off.
Apr 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Cost of repair if they need to replace the T8005(d Board)
hmmm my information says blue tube bad.
sony has a recall on this
http://esupport.sony.com/perl/news-item.pl?news_id=24
Dec 26, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
SONY KP57HW40 TV
Bad green CRT = common problem..........................T.
Oct 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
126 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
