Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
LENS MY LENS ARE STUCK IN THE OUT POSITION AND IT WONT GO IN,IT SAYS TO RESTART IT BUT I DO AND IT STILL WONT GO IN.THIS HAPPENED AFTER I FINISHED VIEWING A PICTURE AND I WANTED TO TAKE ANOTHER.
  • 489 Answers
Hi
There is no camera reset for this model, what you are seeing is a generic stuck lens error message.
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam') $75 is all it takes to install a new lens for you; just let us know if we can help!
Good luck from
Darntoothysam com
Posted on Sep 25, 2008
When I turn on my d90 all I can see is the ISO setting...help
restart you unit. it probably hanged.. . if the unit wont let you restart your cam, then pull off the battery and put it back after couple of seconds
Apr 30, 2010 | Nikon D90 Digital Camera with 18-105mm...
Canon PowerShot A640 lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2009 | Canon PowerShot A640 Digital Camera
Lens got stuck
It sounds like the lens is now out of adjustment and in order for this to be resolved, you will need to take it to a camera repair shop. I have heard good reports about a company called Ritz Camera. Not much else you can do with it unfortunately.
Jun 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Lens stuck...
this happens since the lens section assembly is damages.
and this can be corrected by doing a proper service to it.
and hence i recommend u to take it to some service center for repair.
Jun 16, 2008 | Olympus SP-350 Digital Camera
Camera lens stuck in on position
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Lens stuck
Lens unit faulty and camera has gone into error mode. Repair lens ( several possibilities here ) and reset camera and it will work fine.
Dec 26, 2006 | Fuji FinePix S3100 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
