TV Won't power on
The TV was on, playing fine with no signs of trouble when it shut itself off and now won't turn back on when using the remote control or the 'on' button located on the television . Was watching TV and when I went to turn down the volume the TV shut off. Now it won't turn on using the remote or the power button on the side of the TV.
    Sergeant:
  • 300 Answers
1. Check Power
2. Check Fuses
3. Check Relay
WARNING HIGH VOLTAGE: Do not attempt to work on your set unless another human being is present who is trained in CPR.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division
Posted on Sep 24, 2008
Philips digital tv won’t turn on.
unplug from electric, wait 30 seconds, plug back in. Check that you have power at the outlet (fuse/breaker shut off?) If it has a power word which plugs into the TV as well as the wall, be SURE it is tightly attached to BOTH. Make sure you aren't blocking the remote control receiver (you can turn most TVs on/off on the TV itself -- look for a power button). Be sure your remote has fresh batteries. Good luck!
Jan 14, 2018 | Philips Televison & Video
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
The TV will turn on from remote many times and then won't turn on at all from the remote or directly from the TV itself so we end up unplugging the power which seems to reset the TV and then it
Having to unplug suggests a issue where the set is getting confused, if using any kind of box for signal or have a receiver in line remove power from all and after several minutes plug back.
Dec 17, 2012 | Vizio VS420LF1A TV
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    TV Won't power on
    Maybe need replaced Capacitor beside relay ( 470uf 25v).
    Aug 19, 2008 | Sanyo DS31520 31" TV
    Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
    First try turning the TV on from the Power button the set itself (assuming it has one).
    If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
    Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
    Apr 07, 2008 | Televison & Video
    Televison & Video Logo
    204 people viewed this question
    Top Televison & Video Experts
