Question about HP Officejet 4315 All-in-One Printer
Follow up HP4315 vs MacBook
Thanks for your response.  I'll have to go with Door #1, the wireless adapter set up as a node.  I can probably get someone to help me..
Since I posted my initial query I have looked for an adapter. Checked out a couple of links to no avail.  One particular adapter was listed as compatible with at least two dozen HP printers, but not the 4315.  At that point I gave up & used the USB cable to print.
Could you possibly provide a link to a wireless adapter for a 4315?  In any case, thank you so much for your assistance. Liz / Atlanta
3 Suggested Answers
geemarie
  • 876 Answers
SOURCE: how to install hp4315 officejet all inone
Go to www.hp.com/downloads and enter your printer information and look for a driver to download. Make sure you get the correct one for your Operting system. And when you download, turn off all running programs including your virus control. Good Luck.
Posted on Aug 15, 2008
SOURCE: MacBook and HP 4315
Hello Liz,
You can accomplish your request two different ways. (Both ways are a little technical and you might need assistance)
1) You can get a wireless adapter for your printer and then configure it as a node. Then print to it as a printer device. (node)
2) (cheaper way) You could connect the printer to a spare pc that is wirelesss. Then share out the printer.
Please feel free to ask any additional questions.
George
Posted on Sep 23, 2008
Hey. :) My name is Peyton. And me and my Dad have just bought a "NetGear N150 Wireless USB Adapter", And we've looked at the intructions, and we looked it up. But we can't seem to figure out how...
Installing the Software and Adapter
To install the wireless-N USB adapter with custom setup:
1. Insert the Resource CD. If the CD main page does not display, browse the files on the CD
and double-click Autorun.exe.
2. Click Install the Software.
Select one of the following methods to configure and manage your wireless network:
Smart Wizard. Allows you to manage your wireless networks with the NETGEAR
WNA1000 software and to connect securely using Push 'N' Connect.
Figure 1-1
Figure 1-2
NETGEAR Wireless-N 150 USB Adapter WNA1000 User Manual
1-5
v1.0, August 2009
- Configure network manually. Specify the settings for your wireless-N USB adapter
in the Settings screen.
- Configure automatically. Allow the Smart Wizard to automatically configure the
settings for your wireless-N USB adapter.
Windows Utility. Connect to and manage your wireless networks using only the
Windows configuration utility. For more information about Windows utilities, see the
Windows documentation or the NETGEAR application note at:
http://documentation.netgear.com/reference/enu/winzerocfg/index.htm.
See page 1-3 of the manual:
ftp://downloads.netgear.com/files/WNA1000_UM_05AUG2009.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Computers & Internet
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Can i install adapter to a macbook
You cannot install this adapter on your Macbook , it is only made to work with Windows operating system from windows 98se up to windows Vista, you can try to look for a airport adapter that will surely work with your Macbook...You can check this link for the complete details about this adapter http://cnet.nytimes.com/adapters-nics/netgear-wg111-usb-adapter/4507-3380_7-30791890.html
Hope that helps..............
Oct 03, 2008 | NetGear WG111 802.11g/b Wireless Adapter
MacBook and HP 4315
Hello Liz,
George
Sep 08, 2008 | HP Officejet 4315 All-in-One Printer
NetGear Wireless G USB 2.0 Issues
Jane -- several things are required for internet access.
Lets go through step by step and assure the pieces are in place.
I will assume you have a second machine working with the router (wired or wireless does not matter). I would like you to try the following on both machines at let me know what happens.
First you can connect to the router and not have access to the internet. This first to determine the IP configuration values are correct for your network. (assumes Windows XP and probably Vista) - using the working machine
Click Start then All Programs the Accessories then Command Prompt a new window will open -- in that window type the following (one space only before the /)
ipconfig /all
and press enter -- record the following in the responses
IP Address --------------- probably 192.168.0.?
Subnet Mask ------------ probably 255.255.255.0
Default Gateway -------- probably 192.168.0.1
DNS Address(es) ------ may be more than 1
on your son's laptop do the same -- you should see the following if the configuration is right.
IIP Address --------------- probably 192.168.0.?
Subnet Mask ------------ same as working machine
Default Gateway -------- same as working machine
DNS Address(es) ------ same as working machine
Now test the connection to the router
in the same window as before enter the following command (replace the 192.168.0.1 with the default gateway from the working machine if different)
ping 192.168.0.1
The working machine should display 4 messages with elapsed times indicating the ping works.
Your son's machine may display 4 timeout messages indicating it does not work. If the ipconfig above is wrong especially in matching areas to the working machine that could explain the problem. It could also be that the adapter requires additional wireless configuration such as a WEP or WPA password or passphrase, or connection to your network name (SSID) if it is hidden.
Please respond to this issue with a comment telling me what matched in the two ipconfigs and whether or not the ping works hopefully yes at least on the working machine and I will probably be able to provide a solution to the problem.
Jan 03, 2008 | NetGear Wireless-G USB Adapter...
Printing
You need: * A wireless-enabled computer. Many computers made over the last three years are already wireless capable, or they can operate wirelessly with adapters. * A wireless router. This will serve as your Wi-Fi access point, the hub of your network. * Broadband Internet access. While you can use your wireless router without any Internet access at all, or use dial-up, experts agree that there?s real value in accessing online content via DSL or cable and making it available to every computer in your house. The cost of doing so, like with the hardware, has dropped dramatically in the past several years. When you set up your network using the wireless router, you?ll need to identify that network on each of your wireless computers and during the installation process for your Lexmark wireless printers or all-in-one devices. You?ll be asked about your service set identifier (SSID), which is basically the name of your network. Don?t forget to consider the security of your network early in your decision process. * Common security types for networks include WEP, WPA and WPA2, and there is usually also an option for no security. At a minimum, you should look for WPA or WPA2 security and follow the manufacturer?s instructions to encrypt your signal and set your own password. A password isn't mandatory, but if you don't use one, it's far easier for others to access your network, and potentially your computer.
Sep 08, 2007 | Apple MacBook Pro Laptop Computer with...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
