Question about Palm Tungsten E2 Handheld
I own a Palm Tungsten E2 when I go to hot sync I get an error message that states the connection between your device and desktop could be established please check your setup and try again
  • Bongobeans Oct 10, 2008
    i own a Palm Tungsten E2 when I go to hot sync I get an error message that states the connection between your device and desktop could be established please check your setup and try again
    Please let me know what I can do to get this fixed? Thanks, JB
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
1. Go to your desktop program
2. Go to top and select HOTSYNCH
3. Select Set Up
4. Select the port your E2 is attached to
5. Theres more but I need to know how you are to this point or go to live tech support and ask for Just_Bobz
Posted on Jan 01, 2009
Synchronization
Ensure that when you reinstall the drivers you start reinstalling with phone USB not connected to computer. That is a cause for error 1316.
Try also a replacement usb cable if you have on sometimes a bad cable can give you the error.
Sep 17, 2008 | Palm Tungsten E2 Handheld
Can't transfer infor from palm to desktop
Try going to the Palm home page (www.palm.com) and reinstalling the desktop software. Once you have it reinstalled then do a hotsync. I had the same problem and this worked for me. Hopefully it will clear the problem.
Best wishes.
Sep 13, 2009 | Palm Tungsten E2 Handheld
HotSync problem:connection could not be
After you change the battery you need to do a hard reset. This will erase all the info in your pda so you want to make sure you have it all backed up on the palm desktop To do a hard reset follow these steps:
1. Hold down the power button.
2 While holding down the power button, use the tip of the stylus and inset it into the hole in the back of your pda and gently press and release the reset button in the back of your pda.
3. When you see the message that warns you about erasing all of the info on your hand held select continue.
4. When prompted follow the online directions to align the screen. After that you will want to do another hot sync. Best wishes.
Aug 10, 2009 | Palm Tungsten E2 Handheld
I have a Tungsten E2 PalmOne and it is not sync
Make sure your connection settings are right, obtain latest version of palm desktop at http://kb.palm.com/wps/portal/kb/common/article/33529_en.html You may use USB, Infrared or Bluetooth as alternate hotsync methods
Jan 21, 2009 | Palm Tungsten E2 Handheld
Can I sync an Ipod touch with my Palm Desktop for windows?
I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
Dec 27, 2008 | Palm Tungsten E2 Handheld
Need Hot Sync module on backup PC
Plug your E2 into your pc and when it says new hardware found, install the cd. Do not continue till you have verified sync connection between pc and pda
Dec 11, 2008 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Appropriate software for tungsten e2 palmOne
If you said you have the software (desktop), your doing it backwards. Run the desktop software by going to my pc and running the disc. The software will then ask you to plug in your E2 so it can register it. It will then synch and your in business. Had E2 for a very long time. Can tell you things that guy can do that would surprize you. Have everything but unit now.
Mar 15, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Synching with desktop
Check to make sure the cable is securely plugged in to the USB socket on your computer, and the other end is securely plugged into the Palm device. Unplug them and plug them in again, don't just push on the ends -- if there is dust or something messing up the connection unplugging and plugging in again might shake it loose.
Mar 11, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
76 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
