Question about Nikon D70 Body Only Digital Camera
Nikon D70 Flashing
When depressing the shutter release button half way "ERR" flashes on screen. New 18-200VR lens does not seem to work. Camera does not take any pictures. Please advised as soon as possible I am leaving for a trip in a day and need to take camera along.
Thank you!
Problem fixed.
First tried another lens 55-200VR. When camera was turned on the ERR flashed on display as well. This let me know that this is a camera malfunction.
I then proceeded to released the shutter by fully depressing the shutter release button.
It now appears to work well.
Posted on Sep 24, 2008
  • 3 Answers
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
Can't take picture. "F" is flashing
Flashing "F--" means the camera is not recognizing the lens or a non CPU lens is attached. Try manual mode. Taake battery out of camera, remove lends and clean electrical contacts on lens and camera body with moistened swab, Put back together. Remove battery with camera "ON" and hold down shutter button for about 30 seconds. Put battery back in and turn on. Then Press hardware reset button on camera bottom.
Dec 18, 2010 | Nikon D70 Digital Camera
The LCD continues to flash ERR and although the shutter sounds when the button is depressed, no image is taken.
Hi cpereira27, the manual states on page 132 "press shutter-release button again. If error persists, consult with Nikon authorized service representative". Something else to try is to reset the camera, you will find how to at the bottom of page 129.
Jun 28, 2010 | Nikon D80 Digital Camera with 18-55mm Lens
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
My nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Jan 03, 2009 | Nikon N55 35mm Film Camera
ERR MESSAGE, NIKON D2X
the only time i have ever seen this message on my D2x is when the lens is not all the way snapped on. try re-seating the lens.
Dec 25, 2008 | Nikon D2X Digital Camera
Error message on D70 freezing camera operations
I got this info from Nikon for D70...
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
  1. Remove all accessories from the camera.
  2. Install a freshly charged battery into the camera.
  3. If your Nikon camera offers resets such as the two-button reset or a hardware reset please follow those instructions provided in the product manual.
If these steps do not resolve the Err message we recommend having a Nikon Authorized Repair Technician evaluate the Nikon camera.
Hope this be useful for you to resolve problem.
Nikon D100 randomly has "err" code flashing
You need a new shutter box.
It may be worth cleaning the contacts on both camera and lens.
Clean the contacts in the lens mount using a fiberglass "pencil" designed specifically for cleaning contacts. These are available at just about any photo supply store/firm.
send it to nikon. seem like a common problem
Jan 24, 2008 | Nikon D100 Digital Camera
Nikon D70 - err - won't take picture
Today I was taking photos and the camera quit...the top display says err. The book says release shutter, but I push the shutter and it does nothing but make a little click and the err stays. I took the lens off, and the camera does look like the shutter is open or something.
Sep 28, 2007 | Nikon D70s Digital Camera
Nikon D70 Body Only Digital Camera Logo
252 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
