Question about Proscan PS36123 TV
27" proscan tv
Every once in awhile, the screen shrinks to about a 1" line. In about 5 to 10 minutes the full screen returns. I'm not sure how old this tv is, it was given to me by a friend. Do you think it's worth it to have it looked at?
  • 4,234 Answers
This is a sign that there are either bad caps in the vertical circuit or bad connections at the vertical IC. CAn you solder? If so, resolder the pins on the vertical IC first and post the results here. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar.
Keep us posted.
Posted on Sep 24, 2008
Will not always power up, just clicks and power light flashes. Vertical retrace lines at top 2" of screen. Keeps shrinking and goes completely away after about 5 minutes.
The JVC sets are well known for this type of problem, the tv has a vertical deflection issue needs a few small parts and a touch up on the vertical ic, causes the set to shutdown. I recommend a tv technician for the repair.
Jan 14, 2011 | JVC AV-27750 27" TV
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
Mar 25, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
On my proscan tv, when i turn it on the sound works but nothing comes on the screen, the tv is 8 months old.
i think this is a known problem....some guy in phoenix is selling a bunch of these returned tv's from SEARS with the same problem for $150.00 try to return it.
Mar 02, 2009 | Proscan 32LA25Q 32 in. LCD TV
Sony tv problem
You have a loose solder connection or two. If I knew the model number of the set, I could be more specific. I would expect the repair would run about a hundred dollars, so make sure the picture quality is great before going to the expense.
Aug 02, 2008 | Televison & Video
After a few minutes picture shrinks to single line on screen and then powers off
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Jul 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic 27
Initially I would suspect a problem in the Vertical section of the TV. This could either be the capacitor or the IC itself. In some instances, there are no component failures but rather cold solder joints.
Based on your post/description of :...Once in awhile picture returns to normal...", I am more inclined to think that it is a case of cold solder. which can easily be corrected by reapplying heat on the IC pins or the other associated/nearby components with the use of a soldering iron. Care must be exercised since TV units still pack high voltages even when off and unplug.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Televison & Video
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Sep 11, 2006 | Proscan PS27125 27" TV
Televison & Video Logo
73 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
