I have had the same problem with my planer since it was new. I hate this planer. The way I fixed it was to pull the feed rollers off and put one washer in the hole the pressure springs are on the rollers. I also put about a 1/32 washer under the hold down plate for the roller. It allows the rollers to put more pressure on the wood. Now it works perfect. If it sounds complicated, it will all come together when you take it apart. You take the bottom off to do all this. Trust me it works and is worth the trouble to do it.
SOURCE: My 13" DEwalt Planer feed is slipping and leaving
Hello Ken,
The black marks you are seeing are most likely from the rollers that feed the material threw the planner. The marks are left on the board when the board stops but the feed rollers are still spinning.This occurs when the feed table is stickey with items such as pitch. I would clean off the table completly and wax it ( or some type of lube).
Another cause could be the matrial that you are using, if the stock is real rough it will not slide as easy as a smooth board.
I hope this helps.
Shop Dog.
P.S. after waxing or lubing the table run a scrap piece first to wipe off any excess.
