Question about Refrigerators
We have water under our crispers in our white-westinghouse refrigerator. How can we fix this?
  • Anonymous Jan 25, 2009
    Water keeps getting under my crispers, at the bottom of my fridge.
  • 172 Answers
You have a stopped up drain. The drain is located in the bottom of the back of the freezer. Go in thru the inside of the freezer, remove the back panel and you will see the small opening in the back bottom. It will be frozen up with ice also. Defrost the ice off the drain and try to get hot water to pour down the drain until the drain is clear. I use a flexable piece of hose to blow through the drain until the clog is gone. This will eliminate the water leaking down under the crisper drawers. Good luck and I hope this will FixYa.
Mike
Posted on Sep 24, 2008
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
Water in veg crisper freezing
You have a white cover in the back of your fridge it says twin cool on it. Behind that cover is a drain for your defrost cover that is probably frozen and water is leaking through that cover. Wrap a piece of copper wire around the heater and fish it down the drain and it
will fix the problem
May 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why is the plastic runner on the vegetable crisper so weak?
replacement is the option and the drawer is one piece not a glued guide== the wear and tear actually cut the plastic lip off
Jun 06, 2017 | Westinghouse Refrigerators
I have tried changing the settings on my westinghouse side by side fridge freezer from 3 up to another setting of 5 but it keeps defaulting to 3 and food continues to freeze ,how do I save the new setting?
I found this link to a manual at http://manuals.appliancesonline.com.au/wtm3000pbrh/wtm3000pbrh.pdf . If it was me. The first thing I would do is to unplug the refrigerator for 15 minutes and then plug it back in. I would do this to reset the control board. If you are changing the temperatures and they reset to factory setting then you might have a problem with the control board. Try unpluging it and see if that works first. Refrigerator repair can be difficult and if that does not work you may have to contact a repairman in your area to come out and diagnose it. If I can help you please contact me HERE.
Apr 19, 2013 | White-Westinghouse WRSS25V5GW Side-by-Side...
Whirlpool refridg. accumulating water underneath the crisper drawers. I don't see where it is coming from. What is breaking down?
it is probably condensation from the shiny plastic drawers.i put a piece of kitchen roll under mine once a week...
Apr 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ive had my westinghouse moist cold 421 for quite a few years and lately there has been at times water leaking at the inside under the vegetable cripsers . I'm unable to find my user manual but I recall...
The drip tray is all the way at the bottom.Pull of the grill at the bottom of the refrig,tray should be there.
Also there is a hole or tube under your crispers,check that its clear and not clogged with junk.
Jan 20, 2010 | Westinghouse Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
