Question about LG Dryers
My LG dryer no longer shuts off when clothes are dry. The sensor does not seem to be working. I cleaned the sensors, but still no luck. The clothes still get dry, but I have to turn it off manually before they get too hot.
  • 1 more comment
  • mackenzie_br Sep 24, 2008
    The model I have is electronic, so there is no knob. I am not sure I understand what to do. I did clean the sensors off (the ones inside the drum near the lint filter), but it didnt seem to help. The timer counts down and everything, but it just no longer shuts off automatically when they are dry. So it dries every load for 41 minutes, no matter what - when on sensor dry. Does that make sense?
    It's an LG, Gas Dryer, Front Load...model # DLG2522W.
    Thanks!
  • mackenzie_br Sep 27, 2008
    Thanks! I will check back!
    Scholar:
  • 157 Answers
Hello meckenzie. From your description I would check the timer/controler. If the timer is moving the knob and the leaf contacts are not disconnecting. If this is the culprit and the buget says 'not right now' you have an option, use as is or unplug the AC & open the timer/control housing and use a 'contact brush file' or an emory paper to clean the contacts by carefully seperating them with the file/emory and cleaning the contact surface. If the contacts are not intialy mateing rotate the control unitl they do.
Posted on Sep 24, 2008
  • Gene Pitts Sep 24, 2008
    Hello meckenzie. Thank you for the return reply. I now need "MORE INPUT" like the robot said. Please send the Mgfr., make, model, & serial#. The serial # optional. With this info I will be able to provide more choices in the repair steps.
  • Gene Pitts Sep 26, 2008
    I'm working on it, seeking help on line for the technical info I need to give you all options for your repair. Thank you for your patience,
LG Model DLE1501W - I set the dryer for appropriate cycle. It shuts off after 10-15 mins or so. clothes are still wet.
The moisture sensors seem to be the issue. The two metal bars on the lint filter housing. Try cleaning with alcohol and stop using dryer sheets.
Dec 14, 2016 | LG Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Automatic sensor drying
Hello, Welcome to FixYa. As with most things each manufacturer seems to have their own terminology or "exclusive features" for their products. To answer your question, in a word...Yes. As a general rule "sensor" does indicate an "auto dry" cycle when properly maintained ( as long as the sensors aren't contaminated by way of "wax" build-up over the surface...clean regularly with a rag moistened by "white vinegar" if you us fabric softner or dryer sheets etc. ) and vented that will shut the dryer "off" automatically when sensing the items are dry...depending on the options and cycles selected of course. Hope this answers your question and thanks for visiting FixYa today. Please take a moment and rate the answer if satisfied or let me know if you require further assistance. macmarkus :)
Jul 12, 2010 | LG DLG5932W Gas Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
Dryers Logo
99 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
