Question about Whirlpool Washing Machines
I am looking for a coupling that goes between the motor and the gear box for a 7.5kg Top loading Whirlpool washing machine. it has thick rubber between it, looks like heavy duty belting.
  • marylewis Sep 24, 2008
    How did you get the number so fast!!
    Genius:
  • 1,028 Answers
Part#285753 from whirpool and almost any local appliance parts company
Posted on Sep 24, 2008
  • oldfixer Sep 24, 2008
    replaced 2 last night and at least that many every week ..besides it's 1 of the few part #'s i can remember like agitator dogs 80040
Whirlpool ultra care ll, how to replace rubber coupling?
Flip control panel up, take off cabinet, remove pump off motor, remove motor, and your coupling is on the motor and gear case .
Dec 30, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Mar 31, 2010 | Whirlpool LTE5243D Top Load Stacked...
Washer will agitate but will not spin can hear noise but no movement drains fine im a plumber so that all checks out
there's a coupling that's in between the motor and gear box,remove the pump,unclip the motor,there might be two screws holding the clips in,on the rear motor shaft you'll see part of the coupling,look inside and you'll see the other half connected to the gear box,use a screw driver and pop that part off,then install the two pieces of the new coupling and the rubber that goes in between the plastic parts,i use a 7/16 nut driver and pump plyers to put the pieces on the shafts,line up the plastic piece put the nut driver in the center and hit the nut driver with the plyers,make sure you get the four rubber spacers and put them back on the four corners of the motor,it's easier to reinstall the motor,if you need any more help let me know,the part number is 285753A
Feb 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Estate top-loading washing not spinning
Hello, No this is not the lid switch this is going to be a broken coupling. Whirlpool are usually direct drive machines, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike.
P.s Remember to unplug the power prior to servicing.
Sep 11, 2009 | Washing Machines
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
Washer wont spin
the the motor coupling ..unit want wash or spin,,,if you would lik to try your hand at replacing it lety me know,,onthejob
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills fine but will not spin
the motor coupling is broken. It is a cheap enough part but can be alittle time consuming to replace. it is located directly behind the motor. it is 2 pieces of rubber and i piece of plastic in between the rubber pieces
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine - Need to replace motor cupling on the kenmore 90 series
you have to access the coupling by removing the housing of the machine,
you can tilt it a little bit to the back so that the motor is in your front.
remove the water pump clamps so that you can remove the pump.
unscrew the screws holding the clamps of the motor.( hold the motor tight, it is heavy)
remove the clamps, the motor will fell..
remove the motor and you can see that the coupling is attached to its shaft.
one coupling goes to the shaft of the motor, the other coupling goes to gear box shafting, and the rubber ring is in between the two coupling.
normally, only one coupling is damaged and you can just replace that coupling. you have the other two parts as spare.
i hope this would solve your problem.
tnx 4using fixya,
drcool
Sep 11, 2008 | Kenmore 23822 Top Load Washer
Washer will fill up w/water and wont spin. It still goes through all the cycles.
The fault could be caused by several things, 1. it has a blocked air trap, 2.the lid switch is faulty. 3. The motor to gear box coupling has sheared off or the motor is faulty, there is nothing else that can cause this fault. Regards Engineer
Jul 29, 2007 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
